EFI on an RB - Bracket racing and 10.90 Index racing? #1702872
11/24/14 01:13 PM
11/24/14 01:13 PM
Tulsa, Ok
WadeMetzinger Offline OP
Tulsa, Ok
I’m toying with the idea of moving to electronic fuel injection on my '71 Cuda.
Has anyone on here any experience and success using EFI on a RB? (I'll be putting in on my 540" Frankenstein motor (4.25 stroke, 7.100 rod, 4.5" bore, Indy Intake and 440-1 heads)
I like the idea that the systems are self-learning and can optimize the fuel curve for the motor from Idle to WOT.
But I don’t know a whole lot about them, hopefully once you get it somewhat tuned you can tell it to stop “learning/adjusting” for a given day so it will run consistently. And I’m not sure if anyone has had any success running fuel injection on the throttle stop (I’m planning on doing some 10.90 racing this year)
Also need to make sure they can work with alcohol (the injectors, pumps and the fuel management system)
It would be cool too to be able to switch over to gas or E85 at any time. (or have a separate fuel cell to start/warm it up and after the races to get all the alcohol out)
(I don't know this for a fact but I thought I heard on Drag Week that Larson's truck was using both Alcohol for racing and then switching over to gas for the street and he didn't have to do much more than change the fuel curve set up and switch the fuel supply source and the computer adjusted the fuel curve and injectors)
Who's EFI management system should I consider?
What should I consider as I contemplate this move?
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
Re: EFI on an RB - Bracket racing and 10.90 Index racing? [Re: WadeMetzinger] #1702873
11/24/14 01:27 PM
11/24/14 01:27 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
I've been doing EFI for Mopars for a long time. Check out my web site. Totally self learning systems are great, but for a bracket car I'd suggest that you still want to be able to access certain areas of the program, and you want to be able to datalog each run so you can see which way the system is adjusting. IMO: better than a carb but not totally hands off.
Re: EFI on an RB - Bracket racing and 10.90 Index racing? [Re: Mopar_Rich] #1702874
11/24/14 03:36 PM
11/24/14 03:36 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Yep. I run the local 6.50 index stuff some time. I slow it down over a 1/2 second in the 1/8 to hit the index lol
I just don't open the throttle body as far. Made a screw adjuster to limit WFO.
It's easy to dial on gas. Alcy should print slips like a xerox machine!
Re: EFI on an RB - Bracket racing and 10.90 Index racing? [Re: WadeMetzinger] #1702875
11/24/14 07:06 PM
11/24/14 07:06 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
Wade have you talked to Patrick Melson? He could be very helpful guy to contact on this subject. He recently attended the Holley EFI training. Jim
