Why does tunnel ram work so good on BBmopar not others? #170274
12/18/08 09:00 PM
12/18/08 09:00 PM
Holland MI Ottawa
2
2boltmain Offline OP
Holland MI Ottawa
So why does the tunnel ram work so well on the mopar B and RB but not on others? Dork I knew ran one on his BB chevy pro street camaro and said it would lay down till about 4000rpm and then scream. I had an M1 tunnel ram on a Challenger with 2 500cfm ebrocks. 509 cam and a 10 to 1 shortblock. The thing made power all over. Is it because mopar heads are a velocity torque head? As far as I know small block mopars do not benefit from a T ram like the big blocks do.
Keep old mopars alive.
Re: Why does tunnel ram work so good on BBmopar not others? [Re: 2boltmain] #170275
12/19/08 11:56 AM
12/19/08 11:56 AM
just keep smiling
Re: Why does tunnel ram work so good on BBmopar not others? [Re: RapidRobert] #170276
12/19/08 12:40 PM
12/19/08 12:40 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
Your ready for a new perm.
logan426
Re: Why does tunnel ram work so good on BBmopar not others? [Re: MLR426] #170277
12/19/08 02:07 PM
12/19/08 02:07 PM
Holland MI Ottawa
2
Holland MI Ottawa
I know you guys like my Rob Wolfe-ish wig but what about the tunnel ram question? What do people in the know have to say?
Re: Why does tunnel ram work so good on BBmopar not others? [Re: 2boltmain] #170278
12/19/08 02:15 PM
12/19/08 02:15 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Grumpy Jenkins did ok with a tunnel ram.
Re: Why does tunnel ram work so good on BBmopar not others? [Re: 2boltmain] #170279
12/19/08 03:10 PM
12/19/08 03:10 PM
AndyF Offline
AndyF  Offline
Well your average BB Mopar has intake runners that are about the same size as what was used on a SB Chevy. So my guess would be that the high velocity intake ports work okay with a tunnel ram.
The Max Wedge cross ram is basically a tunnel ram that has been laid over on it side. Those work okay for certain engine combinations too but I don't think they work quite as well as a real tunnel ram.
Re: Why does tunnel ram work so good on BBmopar not others? [Re: 2boltmain] #170280
12/19/08 03:16 PM
12/19/08 03:16 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I think "Dork" is probably the answer and not the tunnel ram. Who knows how well matched the combo was, or how well tuned.
Don't be the exception.
Re: Why does tunnel ram work so good on BBmopar not others? [Re: 2boltmain] #170281
12/19/08 03:47 PM
12/19/08 03:47 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I've had tunnel rams on both a 383 and a 440. Both were dogs at low RPM and forever backfired and blew powervalves in the carbs. I think the 383's issue was a poor cam selection. Neither of them would start without first wearing down a battery. Could never figure if it was a lack of fuel or flooding !! I've had enough of tunnel rams. Can't beat the visual impact though !!!
Re: Why does tunnel ram work so good on BBmopar not others? [Re: Stanton] #170282
12/19/08 04:15 PM
12/19/08 04:15 PM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
Dunno....
Re: Why does tunnel ram work so good on BBmopar not others? [Re: Stanton] #170283
12/19/08 04:18 PM
12/19/08 04:18 PM
Canada
CrAzYMoPaRGuY Offline
Canada
Wow.
Not trying to be mean or anything, but you had issues that were easy to solve.
I've ran 2x4bbl tunnel rams on TONS of vehicles, my Demon was driven year round, in the snow, in the freezing cold, whatever. Started first crank every time, drove like a dream even when cold started.
My work truck was a tunnel ram 2x4bbl- as was my wife's daily driver, for years and years.
I strayed the course when I bought my Jensen Interceptor, it will be a first for me- I went with a lowrise 2x4bbl Edelbrock #5440 (CH28) and two Edelbrock 500s.
I've never ran a lowrise dual quad before, but I want everything under the hood...
CrAzYMoPaRGuY
Re: Why does tunnel ram work so good on BBmopar not others? [Re: 2boltmain] #170284
12/19/08 04:20 PM
12/19/08 04:20 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Is that a Mullet?
Re: Why does tunnel ram work so good on BBmopar not others? [Re: Dragula] #170285
12/19/08 04:21 PM
12/19/08 04:21 PM
GA
roadrunninMark Offline
GA
Damn Dragula, love that one on the left! What is the setup on that one?
Mark
Re: Why does tunnel ram work so good on BBmopar not others? [Re: roadrunninMark] #170286
12/19/08 06:21 PM
12/19/08 06:21 PM
Holland MI Ottawa
2
Holland MI Ottawa
Yes that is a PowerMullet wig I wore for Halloween. Even Weiand does not recommend their tunnel ram on a street driven 440. Sure would have been interesting to see how well the Offenhauser T ram would have done with 2 Holley carbs in that magazine dyno shootout some months back. The Weiand cleaned house.
Re: Why does tunnel ram work so good on BBmopar not others? [Re: 2boltmain] #170287
12/19/08 06:27 PM
12/19/08 06:27 PM
Canada
Canada
I guess I should taken the rep for Weiand out for a ride in my work truck.
Stock stall converter, I could roast the tires while pulling a trailer WITH a car on it...?
Drove it every day, loaded it, towed with it, is was just as drivable as any truck with a carb.
CrAzYMoPaRGuY
Re: Why does tunnel ram work so good on BBmopar not others? [Re: CrAzYMoPaRGuY] #170288
12/19/08 09:44 PM
12/19/08 09:44 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
The reason I've been told they work so well is that the runners are about as close to an ideal length as you can get with an OOTB intake. This is from Don Dulmage's website http://www3.sympatico.ca/big-d/index.htm
" Tuned length of an intake runner.
Runner length is not an exact science because of the variables involved but a rule of thumb formula I often find handy for sorting out manifolds is from Philip H Smith (Tuning For Speed) It states that:
the intake runner should be approximately equal to 90 divided by the RPM in thousands
or
90/rpm in thousands = length in inches
ie for 6000RPM 90/6 = 15 inches
ie for 7000RPM 90/7 = 12.85 inches.
The measurment is taken from the intake valve to the plenum area. If your current 440 Mopar manifold seems too short now for your RPM range you're beginning to get the picture. "
CrAzYMoPaRGuY if you read the 2x4 section of the site he especially likes the 6pak Weiand T-Ram that he converted to 2x4 which looks like the one you have. Lots of good budget minded info on the site.
Kevin
Re: Why does tunnel ram work so good on BBmopar not others? [Re: Twostick] #170289
12/19/08 11:24 PM
12/19/08 11:24 PM
Canada
Canada
Kevin
LOL Good eyes. That's exactly what mine was.
CrAzYMoPaRGuY
Re: Why does tunnel ram work so good on BBmopar not others? [Re: CrAzYMoPaRGuY] #170290
12/19/08 11:41 PM
12/19/08 11:41 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I used to think a dual Dominator equipped Hemi was the coolest TR setup you could run, but I'm thinking this out does those, at least in the awesome/primitive/cool department!
Re: Why does tunnel ram work so good on BBmopar not others? [Re: CrAzYMoPaRGuY] #170291
12/20/08 12:01 AM
12/20/08 12:01 AM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Hard to find reasonably priced.
Kevin
Re: Why does tunnel ram work so good on BBmopar not others? [Re: 2boltmain] #170292
12/20/08 12:25 AM
12/20/08 12:25 AM
WV
bacaruda Offline
bacaruda  Offline
WV
A little off topic, not much, do the STR's work as good?
I'd love to EFI one with a single TB.
Jim.
Re: Why does tunnel ram work so good on BBmopar not others? [Re: bacaruda] #170293
12/20/08 07:05 AM
12/20/08 07:05 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
I pump the carbs a couple times and hit the key and it's running. It runs like a million bucks hot or cold weather. 528 hemi, Weiand TR with 2 850 thermoquads. Dave
