Demon build
#1702739
11/24/14 11:37 AM
11/24/14 11:37 AM
Posts: 625 Indianapolis In. usa
Quickrunner
Did a little cuting this weekend, making room for 315 drag radials.
05 Ram 1500 Daytona package 71 Demon Gen3 hemi drag radial project
Missin' my 9 second 70 runner!
Re: Demon build
[Re: Quickrunner]
#1702741
11/24/14 11:46 AM
11/24/14 11:46 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Looks really good, but all you need is 275/60 pro!
miss my big tires on mine.
Brett Miller W9 cnc'd heads STR Chassis fabraction
Re: Demon build
[Re: 1967dartgt]
#1702743
11/24/14 12:09 PM
11/24/14 12:09 PM
Quickrunner
Yeah I know but I just like the look of the bigger tire, and not really building for a tire size limited class.
Re: Demon build
[Re: Sixpak]
#1702750
11/24/14 03:46 PM
11/24/14 03:46 PM
Posts: 6,350 Aurora, Oh.
max_maniac
Aurora, Oh.
Dave glad to see you getting back in the game. Once you get that one going you will forget all about the RR. Keep us updated on the progess Looks like it's going to be one bad ash ride Russ
Re: Demon build
[Re: Sixpak]
#1702755
11/24/14 11:01 PM
11/24/14 11:01 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
I'll be following your progress, wanting to do the same but with a 325 50 15 M/T Drag radial, which isn't quite as tall as yours, so I am hoping to get away with not having to cut on the fenders, just a mini tub.
I am not sure how big a 325/50 15 Drag Radial is but I ran a 28/10.5 15W under my Demon with stock wheel wells. The leaf springs were moved in 3 in.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
