Re: Demon build
[Re: Quickrunner]
#1702781
12/08/14 02:12 PM
12/08/14 02:12 PM
Posts: 625 Indianapolis In. usa
Quickrunner
Removed tub and crawled in and out of trunk aprox 73 times to get this fit! LOL
05 Ram 1500 Daytona package 71 Demon Gen3 hemi drag radial project
Missin' my 9 second 70 runner!
Re: Demon build
[Re: Quickrunner]
#1702785
12/08/14 04:06 PM
12/08/14 04:06 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Also I did not want to move trunk hinges.
No, I wasn't suggesting moving the hinges. If you look at the very first pic you show.......the hinge panel appears to come down at a bit of an angle towards the center of the trunk. If you had cut the hinge panel straight across the bottom and then just pulled it over a little, you could have welded it directly to top of tub............I know because I have done a few of these..........LOL!!!........but again, your fitting job is outstanding
Monte
Re: Demon build
[Re: 340RICK]
#1702792
12/17/14 01:37 PM
12/17/14 01:37 PM
Quickrunner
Got the passenger side quarter almost finished last night. Will be able to get the wheels and tires up in there tonight to get the measurement for the new Strange S60! Going all out 40 spline, 5/8 drive studs, 3.70 gear, spool, strange dual rear caliper setup.
Re: Demon build
[Re: Quickrunner]
#1702794
12/17/14 01:44 PM
12/17/14 01:44 PM
Quickrunner
25inch front segment -1 inch Calvert split mono's. Smith assassin bars. Sliders at the rear. Reaserching a good arb settup. Cant wait to get this all under it!
Re: Demon build
[Re: Quickrunner]
#1702795
01/23/15 11:45 AM
01/23/15 11:45 AM
Quickrunner
Took a little break, back on it now. Found nice little mouse nest in frame rail! LOL
Re: Demon build
[Re: Quickrunner]
#1702797
01/23/15 11:49 AM
01/23/15 11:49 AM
Quickrunner
Probably going to have to mod the tunnel a bit to get ride height I want.
Re: Demon build
[Re: Quickrunner]
#1702798
01/23/15 11:50 AM
01/23/15 11:50 AM
Quickrunner
This thing is going to look killer when it finally gets back on the ground!
