Re: Demon build
[Re: Quickrunner]
#2628688
03/04/19 02:46 PM
03/04/19 02:46 PM
Posts: 625 Indianapolis In. usa
Quickrunner
Picked up a few more pieces to the puzzle this weekend. Block, 4 inch stroke Callies crank, rocker gear & few other small things.
05 Ram 1500 Daytona package 71 Demon Gen3 hemi drag radial project
Missin' my 9 second 70 runner!
Re: Demon build
[Re: Quickrunner]
#2658089
05/22/19 05:10 PM
05/22/19 05:10 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
Thitek heads and a big Whipple 4.5 on the way, stay tuned! Very cool! Looking forward to seeing it come together
"Just a Bracket car dressed up like a streetcar"
Re: Demon build
[Re: JERICOGTX]
#2663370
06/07/19 08:37 AM
06/07/19 08:37 AM
Quickrunner
Ta Daa!! Now when the heads show up I can get belt drive designed & fabbed up!
Re: Demon build
[Re: Quickrunner]
#2700692
09/25/19 09:01 AM
09/25/19 09:01 AM
Quickrunner
Design of one of a kind accessory drive and and blower drive system for Whipple 4.5 and motorplate application.
Re: Demon build
[Re: Ray408G3Hemi]
#2700741
09/25/19 11:11 AM
09/25/19 11:11 AM
Posts: 20,172 PA.
pittsburghracer
"Little"John
"Little"John
PA.
This build is beautiful from top to bottom. Great job.
Re: Demon build
[Re: Quickrunner]
#2701973
09/29/19 01:09 PM
09/29/19 01:09 PM
Posts: 1,448 Martinsville, IN
cdwmotorsports
Martinsville, IN
First crack at junk HF bead roller, didnt turn out to bad. Getting a flat trunk floor fabbed up. Would you buy the "junk" HF bead roller again or a different one?
eBay-cdwmotorsports
Re: Demon build
[Re: Quickrunner]
#2701980
09/29/19 01:25 PM
09/29/19 01:25 PM
cdwmotorsports
Martinsville, IN
Can you give more details on column mods? I had Bob mod the column for me while he was building my front suspension. Basically he takes the shaft out and cuts the splined end off and puts it in a lathe and turns it to fit a piece of 3/4 moly tube and welds it together. Then cuts the column at the mesh crush area and installs a bushing. The firewall bearing carier is pretty much self explanatory in the previous pics. This is likely gonna be a question I should know the answer to but who is Bob?
eBay-cdwmotorsports
Re: Demon build
[Re: cdwmotorsports]
#2702028
09/29/19 04:03 PM
09/29/19 04:03 PM
Quickrunner
Can you give more details on column mods? I had Bob mod the column for me while he was building my front suspension. Basically he takes the shaft out and cuts the splined end off and puts it in a lathe and turns it to fit a piece of 3/4 moly tube and welds it together. Then cuts the column at the mesh crush area and installs a bushing. The firewall bearing carier is pretty much self explanatory in the previous pics. This is likely gonna be a question I should know the answer to but who is Bob? Bondo Bob, Bob's Profab.
