Page 1 of 20 1 2 3 19 20
Demon build #1702739
11/24/14 11:37 AM
11/24/14 11:37 AM
Indianapolis In. usa
Quickrunner Offline OP
Did a little cuting this weekend, making room for 315 drag radials.
05 Ram 1500 Daytona package
71 Demon Gen3 hemi drag radial project
Missin' my 9 second 70 runner!
Re: Demon build [Re: Quickrunner] #1702740
11/24/14 11:38 AM
11/24/14 11:38 AM
Little quarter surgery is next.
Re: Demon build [Re: Quickrunner] #1702741
11/24/14 11:46 AM
11/24/14 11:46 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Looks really good, but all you need is 275/60 pro!
miss my big tires on mine.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Demon build [Re: 1967dartgt] #1702742
11/24/14 12:09 PM
11/24/14 12:09 PM
ohio
all spooled up Offline
ohio
nice rims what engine u going with
Re: Demon build [Re: 1967dartgt] #1702743
11/24/14 12:09 PM
11/24/14 12:09 PM
Yeah I know but I just like the look of the bigger tire, and not really building for a tire size limited class.
Re: Demon build [Re: all spooled up] #1702744
11/24/14 12:12 PM
11/24/14 12:12 PM
Gen 3 hemi with a procharger is the plan! Have a nice set of Arrington CNC heads and a block for it so far.
Re: Demon build [Re: Quickrunner] #1702745
11/24/14 12:52 PM
11/24/14 12:52 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Yes agree with you on the looks department, but my car is a lot faster on the 275 then the big tires.
Re: Demon build [Re: 1967dartgt] #1702746
11/24/14 01:03 PM
11/24/14 01:03 PM
Think thats due to gearing or rotating mass/weight?
Re: Demon build [Re: Quickrunner] #1702747
11/24/14 01:23 PM
11/24/14 01:23 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
The pro is just that much better of a tire, newer design and compound then the orginal tire. I switched gears between the tires 4.30 with 30" tall radials and 3.91 with 28" tall pros. It's better all over 60' and et and mph.
Re: Demon build [Re: 1967dartgt] #1702748
11/24/14 01:35 PM
11/24/14 01:35 PM
Well, I dont have the $$ to be the fastest guy on radials anyway. I will be plenty satisfied with an 8 second time slip framed in the trailer and a car that looks bad ass!
Re: Demon build [Re: Quickrunner] #1702749
11/24/14 02:36 PM
11/24/14 02:36 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
I'll be following your progress, wanting to do the same but with a 325 50 15 M/T Drag radial, which isn't quite as tall as yours, so I am hoping to get away with not having to cut on the fenders, just a mini tub.
Re: Demon build [Re: Sixpak] #1702750
11/24/14 03:46 PM
11/24/14 03:46 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Dave glad to see you getting back in the game. Once you get that one going you will forget all about the RR.
Keep us updated on the progess Looks like it's going to be one bad ash ride
Russ
Re: Demon build [Re: Quickrunner] #1702751
11/24/14 07:29 PM
11/24/14 07:29 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Looks like I am soon gonna have another super hero besides 340rick to live vicariously through.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Demon build [Re: B3422W5] #1702752
11/24/14 08:44 PM
11/24/14 08:44 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
That wheel is gorgeous.
Sounds like it's gonna be an awesome combo too.
Re: Demon build [Re: ProSport] #1702753
11/24/14 09:15 PM
11/24/14 09:15 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
Going to be a great build to follow
Re: Demon build [Re: 340RICK] #1702754
11/24/14 10:12 PM
11/24/14 10:12 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Nice work. I will watch you built this also as I love the Demon cars. How tall are those tires ? Ron
Re: Demon build [Re: Sixpak] #1702755
11/24/14 11:01 PM
11/24/14 11:01 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
I am not sure how big a 325/50 15 Drag Radial is but I ran a 28/10.5 15W under my Demon with stock wheel wells. The leaf springs were moved in 3 in.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Demon build [Re: D-50] #1702756
11/25/14 12:03 AM
11/25/14 12:03 AM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Thanks, good to know. Moving my springs in as well.
Re: Demon build [Re: Quickrunner] #1702757
11/25/14 12:25 AM
11/25/14 12:25 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Cut away and get that tire up where it oughta be!
Re: Demon build [Re: J_BODY] #1702758
11/25/14 03:48 AM
11/25/14 03:48 AM
Stow ,Ohio
demon440 Offline
demon440  Offline
Stow ,Ohio
Lets see some pictures of that Demon.
