Sway bar brackets #1702481
11/23/14 10:55 PM
11/23/14 10:55 PM
Fischer, TX
dodgepu360 Offline OP
Fischer, TX
Are the sway bar brackets for '72 roadrunner supposed to look like this or should they be more "U" shaped?
Re: Sway at brackets [Re: dodgepu360] #1702482
11/23/14 11:05 PM
11/23/14 11:05 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Those are bent. Feet should be flat & the sides parallel.
Re: Sway at brackets [Re: Alaskan_TA] #1702483
11/23/14 11:41 PM
11/23/14 11:41 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Sway at brackets [Re: Alaskan_TA] #1702484
11/24/14 01:14 PM
11/24/14 01:14 PM
Central TX
roe Offline
roe  Offline
Central TX
Mine look like the first pic. I pulled them from the j/y and left them like that for the install. I assumed they were made that way. Guess I was wrong.
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: Sway at brackets [Re: roe] #1702485
11/24/14 06:10 PM
11/24/14 06:10 PM
Fischer, TX
Fischer, TX
Thanks for the help
I will try and straighten them before I paint them
Re: Sway at brackets [Re: roe] #1702486
11/24/14 07:14 PM
11/24/14 07:14 PM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
Very common as it didn't take much to "tweak" them!
Admiration For Multiple Carburetor Vehicles...
