How to remove the rear seat back on a Duster? #1702418
11/23/14 10:14 PM
11/23/14 10:14 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
I'm removing my seats from my 1970 Duster to be recovered. Today, I removed the front bench seat and rear bottom seat. I have not attempted to remove the rear seat back looked closely at the attachment strategy yet as Sunday family dinner took priority. Any advice on how what I need to do in order to remove the rear seat back?
On another note, I briefly looked through the service manual that I had for 1972 Duster prior to removing any of the seats today and realized there were no interior service instructions in the book. Why is that?
Re: How to remove the rear seat back on a Duster? [Re: vinnyd76] #1702419
11/23/14 10:50 PM
11/23/14 10:50 PM
ohio
bbtrux Offline
bbtrux  Offline
ohio
If I remember right, there's hardware at the floor pan. Remove it and push seat back up.
Re: How to remove the rear seat back on a Duster? [Re: bbtrux] #1702420
11/23/14 11:09 PM
11/23/14 11:09 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Yep, 2 bolts at the bottom, if it hasn't been removed before, then lift straight up off the two hooks near the top.
Re: How to remove the rear seat back on a Duster? [Re: vinnyd76] #1702421
11/24/14 12:08 AM
11/24/14 12:08 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Why am I thinkin' there are steel sheet metal tabs that you straighten to unlock the lower frame of seat back?
Re: How to remove the rear seat back on a Duster? [Re: vinnyd76] #1702422
11/24/14 01:08 AM
11/24/14 01:08 AM
Riverside, California
ghostrider Offline
ghostrider  Offline
I think everyone is assuming you have fixed seat back, is it fixed or the one that folds down?
Re: How to remove the rear seat back on a Duster? [Re: ghostrider] #1702423
11/24/14 03:08 AM
11/24/14 03:08 AM
Ridgeland Wi
mopars_1 Offline
mopars_1  Offline
Ridgeland Wi
a 1970 shouldn't have a fold down rear seat. That didn't come out until either 73 or 74.
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
Re: How to remove the rear seat back on a Duster? [Re: mopars_1] #1702424
11/24/14 09:59 AM
11/24/14 09:59 AM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
I have a fixed rear seat back.
Re: How to remove the rear seat back on a Duster? [Re: vinnyd76] #1702425
11/24/14 12:29 PM
11/24/14 12:29 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Is the A Body the one that has the small steel tabs on the inner wheelhouse that you just bend back out straight and slide the bottom of the seat forward to unlatch? If so lift it off of the top tabs and its out. Usually have to take the armrests off to make it easier to get out. I know the picture is of a Swinger and not a Duster. I enlarged it but just can't make it out.
...FAFO...
Re: How to remove the rear seat back on a Duster? [Re: skicker] #1702426
11/26/14 12:09 PM
11/26/14 12:09 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Attached is a photo of the lower rear seat back attachments. Are these the only attachment points (RH and LH) or should I be looking for other retention points? If these are the only attachments points, any recommendations on how to detach seat back without damaging/over bending tabs?
Re: How to remove the rear seat back on a Duster? [Re: vinnyd76] #1702427
11/26/14 12:45 PM
11/26/14 12:45 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes, sort of.....There are hooks at the top that the top seat horizontal reinforcement wire hangs over to secure the top. They are just hooks that don't move and the seat simply slips onto them. Bend the tabs straight (it won't harm them, they are meant to be bent), pull the lower part of the seat back out towards you, then shove the entire seat back up and it will come off the upper hooks and be free.
Re: How to remove the rear seat back on a Duster? [Re: ScottSmith_Harms] #1702428
11/26/14 01:08 PM
11/26/14 01:08 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
To get the seat back out of the car, remove at least one arm rest also so you have some swing room.
