Mystery 440 block #1702399
11/23/14 09:52 PM
11/23/14 09:52 PM
USA
rftroy Offline OP
rftroy  Offline OP
USA
I have a 440 block with a casting number of 2536430, which, by several sources, makes it a 67-72 block.
The pad on the passenger side at the bottom is blank.
The top pad has markings in font much larger than I have seen on passenger cars - photo attached. There are coarse machining marks; don't know if that's factory, or not.
Marine block, perhaps?
Anyone know?
Robert
AAR 4-speed 3.91, Tor-Red;
70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy;
68 Formula S conv 383 4-speed 3.23, Electric Blue;
69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue;
78 Lil' Red Truck, Red;
70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
Re: Mystery 440 block [Re: rftroy] #1702400
11/23/14 09:54 PM
11/23/14 09:54 PM
rockford illinois
1970A13 Offline
1970A13  Offline
rockford illinois
What is the cast date?
Re: Mystery 440 block [Re: 1970A13] #1702401
11/23/14 10:00 PM
11/23/14 10:00 PM
USA
rftroy Offline OP
rftroy  Offline OP
USA
Oh...yeah.
11/13/68
Re: Mystery 440 block [Re: rftroy] #1702402
11/23/14 10:03 PM
11/23/14 10:03 PM
Oh...yeah.
11/13/68
That means is was cast after the 1969 car where being built and sold as far as the meaning of the marks on the pad Good luck, hopefully someone more in the know on pad markings will chime in
Re: Mystery 440 block [Re: rftroy] #1702403
11/23/14 10:41 PM
11/23/14 10:41 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I've never seen a factory block stamped in that direction. All the ones I've seen are stamped to read correctly as if the were installed in a car and you could read them from the radiator side. Also the font does not look like anything I've seen from the factory. I think someone just stamped the motor for their own purposes.
Re: Mystery 440 block [Re: fastmark] #1702404
11/23/14 10:48 PM
11/23/14 10:48 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Marine block?
Re: Mystery 440 block [Re: Alaskan_TA] #1702405
11/24/14 02:03 AM
11/24/14 02:03 AM
Big Sky Country
MO_PA Offline
MO_PA  Offline
Big Sky Country
M-marine, 440, L-low compression, E-1969
1/1 and 5 ??
Re: Mystery 440 block [Re: MO_PA] #1702406
11/24/14 02:21 AM
11/24/14 02:21 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
WAG - 1/15 = 1/15/69 engine assembly date
any stamped numbers on the bottom?
Re: Mystery 440 block [Re: 6bblgt] #1702407
11/24/14 04:00 AM
11/24/14 04:00 AM
USA
rftroy Offline OP
rftroy  Offline OP
USA
Nope. Nothing stamped on the bottom.
