flat top v.s dome #170227
12/18/08 08:10 PM
12/18/08 08:10 PM
Indiana
79_W200 Offline OP
79_W200  Offline OP
Indiana
i have a 470 setup i would like to use that has flat top pistons and comes to 11.3:1 how much power will that give up vs. a dome setup of about 10 -15 cc to get to 13-14:1 i would like to keep cost down and reuse the pistons i have instead of buying new and rebalancing rotating asb. but if it is a big loss i will go with new pistons
1979 W200 470
Re: flat top v.s dome [Re: 79_W200] #170228
12/18/08 08:23 PM
12/18/08 08:23 PM
SW Ohio
AAR-B4 Offline
AAR-B4  Offline
SW Ohio
My :
Keep the flat tops. It's not just the cost of the pistons but the cost of race fuel.
Re: flat top v.s dome [Re: AAR-B4] #170229
12/18/08 08:29 PM
12/18/08 08:29 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
my 511 ci
is a flat top JE piston
7 cc valve releaf
40 th gasket
and indy sr,s 74 cc chambers
is about 12.7 to 1
1.39 9.85 - 137 mph
Re: flat top v.s dome [Re: 79_W200] #170230
12/18/08 08:49 PM
12/18/08 08:49 PM
mill the heads.
Re: flat top v.s dome [Re: 79_W200] #170231
12/18/08 08:59 PM
12/18/08 08:59 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`d keep the flat tops and mill the heads to up the comp. if you need to. Rumor says flat tops have a better flame front and are more efficient at burning up the fuel. I`m at 12.11 comp. and make good power and drive on 91 and mix 91 and 110 when I race.
Re: flat top v.s dome [Re: 79_W200] #170232
12/18/08 09:02 PM
12/18/08 09:02 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
above 11/1cr each point is worth about 10hp.the gains are less than going from 8/1 to 9/1 as shown in a mopar test changing head gasket thicknesses where the gains were 15hp per point in cr.
Re: flat top v.s dome [Re: blownzoom440] #170233
12/18/08 09:08 PM
12/18/08 09:08 PM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
i have run as much as 42 degrees of timing with domes and 906 heads and as little as 34 with flat tops and better heads. you can order a set of custom thickness cometic head gaskets. i just put on a set of .027[i think] cometics. keep the flats.
Re: flat top v.s dome [Re: tjmarcus1] #170234
12/18/08 09:13 PM
12/18/08 09:13 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
Another vote for flats here tooooo .... but maybe even a DISH !! (if you can still keep a decent compression ratio)...I have been told that THAT design can enhance air-fuel atomization.
Re: flat top v.s dome [Re: dOrk !] #170235
12/18/08 10:40 PM
12/18/08 10:40 PM
Indiana
79_W200 Offline OP
79_W200  Offline OP
Indiana
if the 10 h.p. per point is true i think i will live with 15-25 h.p. less and keep the flat tops just didn't know how much it would loose i didn't know how much the cr would effect hp and tq vs the flame travel on a flat top thanks for the info
1979 W200 470
Re: flat top v.s dome [Re: 79_W200] #170236
12/19/08 05:24 AM
12/19/08 05:24 AM
ELYRIA,OH
ELYRIA,OH
there may be an easier way to get that HP you want by picking apart your combination to find the details of where to look.i am sure your engine runs good but i am interested in the parts,tuneup your engine has to make sure you are getting the most from it.there is certainly no shortage of help around here.
Re: flat top v.s dome [Re: blownzoom440] #170237
12/19/08 07:01 AM
12/19/08 07:01 AM
Indiana
79_W200 Offline OP
79_W200  Offline OP
Indiana
400 block 3.90 stroke 4.375 bore 6.76 rod piston comp height is 1.25 0 decked have to run stock heads so i have ported 915 chambers measure 77cc going to roller cam setup with crower cam
int 268 exh is 282 at .050 will go with victor int. and i think a 2 or 2-1/8 header open exh have engine is apart for winter check up and i am planning to install a girdle or go to al. main caps do to the plan of pushing it harder this coming season my heads are o-ringed so milling them would require more work i think how much cr does this need will 11:1 range work ok
1979 W200 470
Re: flat top v.s dome [Re: 79_W200] #170238
12/19/08 06:20 PM
12/19/08 06:20 PM
ELYRIA,OH
ELYRIA,OH
did you have the cam advanced at all?
were you going to use spray with that cam?
Re: flat top v.s dome [Re: blownzoom440] #170239
12/19/08 06:57 PM
12/19/08 06:57 PM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
I dident see anyone mention that flattops are much lighter! my pistons are essentially flattops
that weigh 470 grams a piece
