motor mount dilemma question #1702206
11/23/14 01:56 PM
11/23/14 01:56 PM
vermont
chere1020 Offline OP
vermont
I need your expertise again. Does anyone know does the 318 engine motor
mounts [ block mounts and rubber mounts ] out of a 1968-1969 4dr Plymouth
satellIte fit a 1970 charger?????? Please email me if you know this answer or if you know how I find out for my boss. Thanks in advance. Sherry
Re: motor mount dilemma question [Re: chere1020] #1702207
11/23/14 10:08 PM
11/23/14 10:08 PM
They should, Mopar did change the V8 K members in 1970 so they would fit both the E and B bodys but no changes to the engines steel and rubber mounts as far as I know IHTHs
Re: motor mount dilemma question [Re: Cab_Burge] #1702208
11/23/14 10:43 PM
11/23/14 10:43 PM
Abilene, Texas
fastmark Online content
fastmark  Online Content
Abilene, Texas
Should fit as long as you are putting a 318 in the 70 Charger.
Re: motor mount dilemma question [Re: fastmark] #1702209
11/23/14 11:06 PM
11/23/14 11:06 PM
scratchnfotraction Offline
should fit a 340/360 with some washers/spacers on 1 bolt on driver side 318 block mount as well.
Re: motor mount dilemma question [Re: scratchnfotraction] #1702210
11/27/14 12:26 PM
11/27/14 12:26 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
they are the same 273-318 from 1966-1972 on all B,C,E as they all use the same rubber motor mount insulator....right and left interchange.
the steel brackets are left and right sensitive meaning there is a drivers side and a passenger side steel bracket.73 c-bodies stayed the course with those brackets also....not changing to spools till 74. now getting into the 340-360 engine series.....using 273-318 mounts....on the passenger side bracket....using 273 passenger side bracket on 340-360....you have to drill one hole straight across the bracket.the passenger side 318 bracket is a direct bolt on to 340-360 blocks...the drivers side 273-318 bracket will bolt on to the 340=360 engine blocks. all the ears line up to the corresponding holes in the steel bracket.however on one ear on top there will be a gap between the ear of the block and the inner flat of the bracket.easy way is bolt the steel bracket to the ears of the block with the two that are fluch.fill in the gap with washers or a homemade spacer.tighten. the above information is for B,C,E bodies not A.
