Re: Best gas mileage with 360?
[Re: HotRodDave]
#1701981
12/08/14 04:01 PM
12/08/14 04:01 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
I had to do some pretty major mods to get my 2wd 318 ex cab ram to get over 20 mpg @75 mph. Very tall narrow tires, zero deck the block .039 head gaskets, ford 4.6 injectors, advance crank sensor, electric fan, 205 t-stat... of course at 55 it would easily get 25 mpg.
[Re: HotRodDave]
#1701983
12/10/14 11:18 AM
12/10/14 11:18 AM
Posts: 4,862 the frozen wastes...
Pale_Roader
Swears too much
Swears too much
And about gear ratios, I have not really found a low ratio to help any in town. I used to think it would but none of my testing on many different vehicles showed they got better MPG with a low ratio in town.
It might for a slant six, but even a bone stock 360 will have enough grunt to move pretty much any car. No matter what the engine is... a low rearend gear will always be climbing the tach. There is NO way around that, without driving like a goof anyways.
My stock 78 4dr Volare had a factory 360 and that thing got nearly the MPG my 96 Mustang GT (4.6mod, 5-speed) did. It was more than fast enough to play a bit, had a surprising top end (130mph before the engine couldn't push any more gear) and it got crazy MPG. I was lazy with the calculating, but it was in the 20's. I'm not an idiot when i drive, i am exceedingly skilled at hypermiling, but i never drive slow. The 2.45 rear gear had a LOT to do with all this. It was so all-around useful and efficient i wish i could get a 2.45 gear for my Challenger's 8 3/4". That Volare accelerated just fine too.
Take what i had, put it in my 700lbs lighter Challenger, clean up the heads, add a modern intake, add a real headers/exhaust (that stock single with cat was a complete joke, making it even more impressive), better ignition, all the cheap tricks and it would kill that Volare in efficiency. If i threw an 8 1/4" with 2.45 in it too anyways.
Do all that, but to a Magnum 360... better compression, less internal friction, way better heads, RPM intake and carb, roller cam... I bet you could get some pretty impressive MPG yet, more than we've seen so far anyways.
Find a way to jam a 5-speed in there too... yummy. This is where i'm going with my car. Just haven't quite decided on the details yet.
[Re: 360view]
#1701985
12/11/14 11:16 AM
12/11/14 11:16 AM
Pale_Roader
Swears too much
Swears too much
Tires vary a lot in rolling resistance new, and even more so as the tread wears down, so between best and worst tires there might be as much plus or minus 2 MPG from the factory tires.
Tires can vary a LOT. On my 96GT Mustang i've had a few different tires over the years. When i first got it i had these old BFG Comp T/A's... probably one ov the first Z-rated to really attack the aftermarket. Threw them on and holy [Edited by Moparts - Family Friendly Site - Keep it clean]... they were LOUD. Remarkably loud. After a few months i found some newer tires, swapped 'em and noticed immediately how quiet the car was, and also how much further the thing would coast once off the gas in neutral. Rolling resistance has always been in the back ov my mind, but this clearly illustrated how huge this can be. That was switching to some other super HP Z-rated summer tire too. There are 'high mpg' tires out there that i'm sure would be the same difference between my best tires and them. They'd handle like garbage, but i bet that car'd roll forever.
[Re: 360view]
#1701987
12/11/14 06:09 PM
12/11/14 06:09 PM
HotRodDave
Kalispell Mt.
I zero decked a 98 318 magnum and used .039 head gaskets and got an solid 2 mpg improvement around 75mph. It helped a tad at low speed but the biggest gains were high speeds. I re-used the rings and bearings, cam... every thing the same before and after. Both had no fan. I added 20 inch wheels and tires that were about 10% taller then the 16s I had on before and got another 1 MPG at 75mph. I sold the truck to my dad who drives super slow to save gas and he said he had to speed up to get good mpg from it. At 60 mph on the highway he said it don't do any better than 80mph.
[Re: HotRodDave]
#1701988
12/11/14 06:11 PM
12/11/14 06:11 PM
HotRodDave
Kalispell Mt.
My test of tire rolling resistance is to see how hard it is to push around the shop by myself.
[Re: HotRodDave]
#1701989
12/12/14 12:08 PM
12/12/14 12:08 PM
Pale_Roader
Swears too much
Swears too much
So basically... you overhauled it, JUST to change the quench? How come every time i suggest that i just get weird looks...???
Its too bad all this Magnum talk is largely limited to big ridiculously heavy trucks. I'd love to have a nice big database ov what these engines do in lighter cars (like we have with old 318's and 360's, and 340's).
[Re: HotRodDave]
#1701990
12/12/14 03:08 PM
12/12/14 03:08 PM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
Pushing a vehicle around the shop can be almost scientific if you take a bathroom scale and press with it against the vehicle bumper. Get a vehicle moving first, then read on the bathroom scale how many pounds force it takes to move steadily. If it takes 50 lbs to keep a 5000 lb vehicle in steady speed movement, those tires have 1% rolling resistance. The best new low RR tires claim about 0.7% with new deep tread. Thats about 39 lbs for a 5500 lb Ram. I think i will go out and whip together a custom wheelbarrow that uses a Ram 5 on 5.5 wheel in the front, and has a "trapped" digital bathroom scale pressed on by the handlebars. Would the tire store employees call the police if i wheeled that contraption into their store, and asked for fittings?
[Re: 360view]
#1701994
12/15/14 02:44 AM
12/15/14 02:44 AM
DaytonaTurbo
Manitoba, Canada
Mazda has now proven that 13 to 1 compression is possible with 87 AKI regular, which is actually closer to 85
Yes but difficult to replicate in an engine without direct injection like mazda uses.
But if you are building a Dakota for MPG it is hard to arguing for using a 360 when dual plug 5.7 Hemis with their 27 inch long intake runners are available for just a little more money.
Perhaps not an issue in your area, but around here good running 5.7's are still going for 3x the cost of a comparable 5.9. Not to mention dealing with the 5.7's ignition system in a swap is not a simple or cheap affair where the 5.9 will take any old SB distributor. The Hemi is superior, if you can bank roll it. Sometimes in a budget project, a guy just can't justify it.
[Re: 360view]
#1701995
12/15/14 03:26 PM
12/15/14 03:26 PM
HotRodDave
Kalispell Mt.
I have everything to do the 5.9, thats the only reason I can even consider doing it, otherwise I am going straight to the 410 stroker I have been piecing together. I have KB107 4.030 pistons, the truck has long tube headers dual exhaust with an x pipe. It is 2 inches lower than a normal dakota R/T even. I have a set of narrower LRR tires. I can push it around the shop with one hand right now (currently has 392 stroked 318 magnum). I have lots of injectors I can play with. I went and looked I have 2.76 3.55 3.92 and 4.56 gears to pick from. I don't think you could go 13 to one without direct injection, they are injecting the fuel after it is too late to cause pre-ignition. I already built the a-500 to handle gobs of power so not converting to a manual that either don't fit or can't take the power (the 410 will still be the long term goal ) I can lean it out real good by putting in low flowing injectors and leaving the O2 unhooked so the confuser don't adjust the fuel trim Also I would think the NOX would be through the roof with HC going down real low. I will go break a ex valve in half and see if there is sodium in it
[Re: 360view]
#1701997
12/16/14 06:43 AM
12/16/14 06:43 AM
Pale_Roader
Swears too much
Swears too much
I REALLY wish people would quit with this fantasy.
Better? Yes. Way yes. OBVIOUSLY. 'Just a little more money'...??? To someone with a heavy 6-figure income, and a shop with 4 hoists maybe. To me, and i'd wager more than a couple guys here, a few thousand dollars is not 'just a little more money'...
