Door handles on my 37
#1701669
11/22/14 01:05 AM
11/22/14 01:05 AM
Posts: 18,575 Dreaming of the 808
AZ_A12_BEE
Dreaming of the 808
Correct me if I'm wrong but the the only way to open the doors is from the outside door handle? If you are inside you have to roll down the window and reach outside to open the door?
69.5 A12 Bee, first purchased in 1976, car 169 on registry
69 Coronet R/T 440/4 spd
69 Coronet 500 Conv H code 383 4bbl/auto
37 Plymouth PU
Find your spot on earth and ride it.
Re: Door handles on my 37
[Re: moparx]
#1701671
11/23/14 11:09 AM
11/23/14 11:09 AM
Posts: 1,510 AZ
Mike P
AZ
".....um, only if they are broken. you should have inside release handles. if none are there, some previous owner removed them[and the connecting mechanism ?]for whatever reason......" Yup. The inside handle/latch mechanism also acts as your door lock. Pushing forward on the handle opens the door and pulling back locks it. Like many trucks of this era (and clear into the early 50s) you will notice that there is no key hole or cylinder on the outside of the drivers door but there is on the passengers door. You cannot exit the drivers door, set the lock and close the door as it will unlock the door again. To lock the truck up you must set the the drivers door lock, slide across the seat and exit the passenger door then lock that door with the key. This was actually done as a safety feature to force the driver to exit the truck on the curb side. At least that was the factory propaganda at the time.......I think they were just too cheap to spring for the second lock. Of course back then hardly anybody lock their doors anyway.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold 1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold 1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears)
[Re: Mike P]
#1701672
11/23/14 01:00 PM
11/23/14 01:00 PM
moparpollack
Lil Herman
Lil Herman
85086
Thank you I always wondered how this worked!
[Re: Mike P]
#1701673
11/23/14 06:33 PM
11/23/14 06:33 PM
AZ_A12_BEE
Dreaming of the 808
Mike thanks, you just explained it to me and my truck is correct and not broke, I can lock my drivers door but not open the door from the inside, the passenger door you can both lock and open from the inside, great info
37 Plymouth PU
[Re: AZ_A12_BEE]
#1802519
04/13/15 05:43 PM
04/13/15 05:43 PM
Posts: 678 Marshall TX
Texas383
Marshall TX
I have a '50 Ford F-1 that has passenger's door lock only. 2nd lock optional in '51, standard in '52. Ford literature claims it was for driver safety to exit/enter vehicle on curbside away from traffic.
I'm considering getting a '37 D5 Touring Sedan.... will be watching your posts on your resto to see if they can help me if I get a '37
1969 Y2 Super Bee 1959 Coronet 4 dr Sedan
~ I intend to live forever...so far so good! ~
TO GOD BE THE GLORY!!
