Re: Oil Filters
[Re: 71birdJ68]
#1701552
11/21/14 11:01 PM
11/21/14 11:01 PM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
I was watching a seminar about oil filters by a retired Chrysler design engineer on the Modern Performance web site the other day, and was wondering what you all thought. He's said that the pop off valve in most filter open at around 10 lbs. pressure, and as a result around 20/ 25 percent of the oil doesn't get filtered, so, he recommends a filter like a STP that doesn't have a pop off valve. SO, what do you all think?
Look at the inside of a STP filter, the ones I have seen have a flimsy looking plastic frame.
Re: Oil Filters
[Re: 71birdJ68]
#1701557
11/22/14 05:52 PM
11/22/14 05:52 PM
Posts: 43,305 Bend,OR USA
Cab_Burge
I've used about every brand and type oil filter out there for stock BB and SB Mopars. None of the screw on type stock replacemnt oil filters I've cut open, including STP, didn't have the bypass valve and spring in the bottom of the filters, none of them The Wix and Fram race filters bypass at a lower pressure If you don't want to use a oil filter with a internal bypass use one for a GM motor like BB and SB Chevys use I don't and wouldn't ![](/ubbthreads/images/graemlins/Twocents.gif)
