What Rearend is This? #1701442
11/21/14 12:17 PM
11/21/14 12:17 PM
Urbana, MD
bordin34 Offline OP
bordin34  Offline OP
Urbana, MD
I found this on craigslist and its listed as a sure-grip 9-1/4" from a 1977 New Yorker. I thought the cover on should be more of an octagon than whats in the picture. Can anyone confirm it is a 9-1/4" before I drive to find out. It will be going into my 73 Charger. Also is the bolt pattern 5x4.5 and not the larger imperial pattern?
Re: What Rearend is This? [Re: bordin34] #1701443
11/21/14 12:36 PM
11/21/14 12:36 PM
scratchnfotraction Offline
looks like a 12 bolt 9 1/4 from a car to me.
perches are for axle on top of springs = car
pinion snubber = car
axle tubes swagers down to smaller end cups at backing plate = 9 1/4
cover has 12 bolts = 9 1/4
cant see wheel bolt pattern in pics but most likly 5 on 4.5
if it is 5 on 5.5 then you could swap in some 9 1/4 axles with 5 on 4.5 wbp
Re: What Rearend is This? [Re: scratchnfotraction] #1701444
11/21/14 12:42 PM
11/21/14 12:42 PM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
Axle I.D.
It would need to be narrowed to put into your Charger. I think its about 1 1/2" wider overall.
John
Re: What Rearend is This? [Re: SattyNoCar] #1701445
11/21/14 12:50 PM
11/21/14 12:50 PM
Urbana, MD
bordin34 Offline OP
bordin34  Offline OP
Urbana, MD
Thanks I saw the axle ID image already thats what prompted me to ask the question. In the image it shows the 9-1/4 being almost a perfect octagon. In the picture I posted it looks like one half the octagon is rounded.
Re: What Rearend is This? [Re: bordin34] #1701446
11/21/14 01:04 PM
11/21/14 01:04 PM
Urbana, MD
bordin34 Offline OP
bordin34  Offline OP
Urbana, MD
It also looks like I should be able to just fit my tire and wheel package with this rear. I may need to roll the fenders a bit just to be totally safe.
Re: What Rearend is This? [Re: bordin34] #1701447
11/21/14 01:20 PM
11/21/14 01:20 PM
All the 9 1/4 I've sen have tapered axle tubes(they step down about halfway the brakes backing plates), the 8 1/4 don't
Re: What Rearend is This? [Re: Cab_Burge] #1701448
11/21/14 01:51 PM
11/21/14 01:51 PM
Urbana, MD
bordin34 Offline OP
bordin34  Offline OP
Urbana, MD
Thanks. I know it is not an 8-1/4". I am trying to 100% confirm it is a 9-1/4"
Re: What Rearend is This? [Re: bordin34] #1701449
11/21/14 05:55 PM
11/21/14 05:55 PM
Do the axle tubes step down? If not probally not a OEM Mopar 9 1/4 There is nothing wrong on the stock 8 1/4 rear end, the 8 1/4 rear ends work good
Re: What Rearend is This? [Re: Cab_Burge] #1701450
11/21/14 06:39 PM
11/21/14 06:39 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
There is a step in the tube in the pic.
It is the older 9.25 cover, they were round and turned octogonish later but I don't remember the year they changed.
As a side note for you rear end gurus, I have a 9.25 rear with full floating axles out of a one ton, I actually have two of them, any one want to guess where they came from?
Re: What Rearend is This? [Re: HotRodDave] #1701451
11/21/14 06:56 PM
11/21/14 06:56 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I'm guessing those full float 9 1/4s came out of 90s & newer "B" vans.
The rear axle pictured looks like a 9 1/4 to me as well. I suspect that Limited slip has 2:76 or maybe even 2:45 gears! I also suspect its older then 77, by 77 I thought all Mopars except trucks had the rubber mounted leaf spring brackets. I believe 74 or 75 was the year Mopar went to the rubber mounts across the board, and some were earlier then that. Gene
Re: What Rearend is This? [Re: poorboy] #1701452
11/21/14 07:25 PM
11/21/14 07:25 PM
Urbana, MD
bordin34 Offline OP
bordin34  Offline OP
Urbana, MD
It wouldnt be possible to tell if it has the iso setup from this angle. The perches are very similar except for the height and center hole diameter.
My Charger currently has a 440 9.6:1 with a 60303 cam, and 440source heads with a 2.45 open 8-1/4" rearend. So anything in the rearend is an upgrade. Going from the 77 Chrysler brochure sure-grip was only available in the New Yorker with the 2.7 or 3.2 ratio. 2.4 would be special order and open.
Re: What Rearend is This? [Re: bordin34] #1701453
11/27/14 12:53 PM
11/27/14 12:53 PM
Urbana, MD
bordin34 Offline OP
bordin34  Offline OP
Urbana, MD
I picked up the rear yesterday. I would say it was worth it for $100. I took off the cover and it had a weird fuzzy rust all over it. The consistency of it was like someone poured bread crumbs onto the diff. I could take my finger and wipe it all away down to clean metal. I sprayed PB blaster all over it and nearly all the rust is gone now.
Re: What Rearend is This? [Re: bordin34] #1701454
11/27/14 01:01 PM
11/27/14 01:01 PM
I had a 8 1/4 that looked sorta like that.
I used a pressure washer with some purple cleaner to flush it good and slowly turned it by hand to till the bearings were flushed good added oil and it is still up and going.
I would suggest pulling the axles and have a look at them to see if they are rusted and need a cleaning also.
Re: What Rearend is This? [Re: scratchnfotraction] #1701455
11/27/14 04:13 PM
11/27/14 04:13 PM
Urbana, MD
bordin34 Offline OP
bordin34  Offline OP
Urbana, MD
After looking at it more I think I am going to replace the ring and pinion and all bearings.
There is a very small sliver about the size of a clipped thumb nail off the outside edge of the coast side of every tooth on the ring gear.
Re: What Rearend is This? [Re: bordin34] #1701456
11/27/14 08:12 PM
11/27/14 08:12 PM
Harm City Md.
Dan Halen Offline
Dan Halen  Offline
Harm City Md.
Look how thin that ring gear is, can't be much gear in that rear.
Re: What Rearend is This? [Re: Dan Halen] #1701457
11/27/14 10:21 PM
11/27/14 10:21 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Dana 53?
Re: What Rearend is This? [Re: dart4forte] #1701458
11/28/14 01:02 AM
11/28/14 01:02 AM
Urbana, MD
bordin34 Offline OP
bordin34  Offline OP
Urbana, MD
It is a 9-1/4 that came out of a 1977 New Yorker parts car. The ratio is 2.7. I'll try to take a picture of the chipped gears and post it.
Re: What Rearend is This? [Re: bordin34] #1701459
11/28/14 01:13 AM
11/28/14 01:13 AM
Urbana, MD
bordin34 Offline OP
bordin34  Offline OP
Urbana, MD
Here is the best picture I could get. Look at the sliver missing from the edge of the coast side. It is nearly identical on every tooth. Also as you can see nearly all the rust wiped right off.
Re: What Rearend is This? [Re: bordin34] #1701460
11/28/14 01:18 AM
11/28/14 01:18 AM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
If I were you I would cut my loses, the wrong rear end, not a popular design (but a decent one), needs gear set and bearings at a minimum, need to verify lug pattern, have to buy special offset wheels to center the tires correctly or get any size tire in the wheelwells. I think you are gonna spend a lot more money than if you just bought an 8.75, maybe the same money but you would have argueably a lesser rear end. Obviously it would have been a better decision before you spent the $100 but no reason at this point to continue to dump money into a bad idea.
Careful, your character's showing!
Re: What Rearend is This? [Re: mopar346] #1701461
11/28/14 01:30 AM
11/28/14 01:30 AM
SattyNoCar Offline
SattyNoCar  Offline
I almost have to agree with mopar346. Yeah, your buy-in was cheap, but, how much are you going to end up spending to overhaul that? And you're going to have to weld on new perches too.
I've got a non-rusted version of that that's been sitting in my garage for YEARS because I can't give it away, yet, I can't bring myself to scrap it either.
John
