Re: What Rearend is This?
[Re: Cab_Burge]
#1701450
11/21/14 06:39 PM
11/21/14 06:39 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
There is a step in the tube in the pic.
It is the older 9.25 cover, they were round and turned octogonish later but I don't remember the year they changed.
As a side note for you rear end gurus, I have a 9.25 rear with full floating axles out of a one ton, I actually have two of them, any one want to guess where they came from?
[Re: HotRodDave]
#1701451
11/21/14 06:56 PM
11/21/14 06:56 PM
Posts: 10,562 Freeport IL USA
poorboy
Freeport IL USA
I'm guessing those full float 9 1/4s came out of 90s & newer "B" vans.
The rear axle pictured looks like a 9 1/4 to me as well. I suspect that Limited slip has 2:76 or maybe even 2:45 gears! I also suspect its older then 77, by 77 I thought all Mopars except trucks had the rubber mounted leaf spring brackets. I believe 74 or 75 was the year Mopar went to the rubber mounts across the board, and some were earlier then that. Gene
[Re: mopar346]
#1701461
11/28/14 01:30 AM
11/28/14 01:30 AM
Posts: 16,819 Between Houston & Galveston TX
SattyNoCar
I almost have to agree with mopar346. Yeah, your buy-in was cheap, but, how much are you going to end up spending to overhaul that? And you're going to have to weld on new perches too. I've got a non-rusted version of that that's been sitting in my garage for YEARS because I can't give it away, yet, I can't bring myself to scrap it either.
John
