roller cam Distributor gear selection #1701426
11/21/14 03:19 AM
11/21/14 03:19 AM
colorado
9
929lamasters Offline OP
colorado
I have a Comp Cams Hydraulic Roller Retrofit Cam .549/.544. I wondering if anyone has used the Crane steel Distributor gear? They claim can be used on a billet steel cam instead of a bronze gear that comp recommends. My car is a street strip car thank you for the help
Re: roller cam Distributor gear selection [Re: 929lamasters] #1701427
11/21/14 03:26 AM
11/21/14 03:26 AM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
The crane gears DO work as long as the cam is brand new.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: roller cam Distributor gear selection [Re: HemiRick] #1701428
11/21/14 03:40 AM
11/21/14 03:40 AM
colorado
9
colorado
It is new
Re: roller cam Distributor gear selection [Re: 929lamasters] #1701429
11/21/14 04:37 AM
11/21/14 04:37 AM
Is your roller cam a steel billet core or a cast endural core ?(they look like the stock OEM cams)
Re: roller cam Distributor gear selection [Re: Cab_Burge] #1701430
11/21/14 11:46 AM
11/21/14 11:46 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
This makes no sense to me. The cam does not wear (if previously used with bronze gear), has no special coating, etc. so what difference does it make if its new or not? I open to an explanation but I suspect this is an old wives tale perpetuated by right-wing liberal religious fanatics intent on striking fear into the average joe.
