Re: Where to purchase leaf springs? [Re: 383man] #1701412
11/23/14 11:08 PM
11/23/14 11:08 PM
Ball Ground, Georgia
Dixie Offline OP
Dixie  Offline OP
Thanks for the compliments on the car, guys. The camera hides a lot of flaws. But, for a High School car, it's works fine. Door dings are gonna happen. He can drive it and not panic if he gets caught in the rain.
The rear tires are probably a bit too tall. I got a screaming deal on them and the wheels, so I bit. I think they are 255/60/15's off the top of my head. They are almost new, so when they wear out, we'll get a smaller set. Of course, I hope that takes awhile.
One item of note. I had the front end originally a little lower. I put the tires on it and had them balanced, the new weights are larger. They hit the upper a-arms. So, by raising the height a little, I got them to clear. All I want for Christmas is a tire changing machine and a few tons of good old fashion lead weights!
Dixie Restoration Parts
Phone -(770) 975-9898
Phone Hours: M-F 10am-5pm EST
website: www.dixierestorationparts.com
email: mail@dixierestorationparts.com
Veteran owned small business
The Best Parts at a Fair Price.
Re: Where to purchase leaf springs? [Re: Dixie] #1701413
11/24/14 12:33 AM
11/24/14 12:33 AM
IN
ahy Offline
ahy  Offline
IN
As several have posted, adding a leaf may be a cost effective fix. One full leaf at my local spring shop costs $100 and change and increases height by about an inch... stiffness also.
Re: Where to purchase leaf springs? [Re: Dixie] #1701414
11/24/14 12:39 AM
11/24/14 12:39 AM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Less cost than Eaton, but still good selection and quality are leafs made by Stanley Springs in Harrisburg Pa. Contact them for a local supplier. Otherwise, see what shipping is from Stengel Bros.
http://www.stengelbros.net/Leaf-Springs_c_177.html
At the bottom of the page is a link to listings of springs available by application.
Having gone the helper spring route as a greenhorn, allow me to suggest ditching them at the first opportunity. They really are best for situations where there is extra weight being carried in the rear. They make the rear stiffer (in the upward direction) and in doing so make the car more likely to fishtail and spin.* This is worse at higher speeds (like a highway to highway interchange) and slicker conditions. Don't ask me how I learned this before I understood this...
You can get a little more ht in the rear by cranking up the front. Factory spec on front ride ht for Dart/Valiants is about 2 1/8" IIRC. That's from the bottom of the t-bar anchor to the lower ball joint. If you change the ride ht, then reset camber, caster, and toe in that order.
Leaf and coil springs do lose rate and hieght after 75 - 100,000 miles. Quicker if abuse (overloaded, raced with stickies) and longer if only driven on smooth roads by super smooth driver weighing 95 pounds. Also the interleafs wear out, but those and the clamps (bands) can be replaced.
*edit: With extra weight on the rear, the extra spring rate won't tend to cause fish tailing. One method trucks and utility vehicles use to get best of both worlds is have a bottom leaf whose ends hang in the air until there's a bunch of weight in the bed and the leaf pack flattens enough to touch.
Re: Where to purchase leaf springs? [Re: Mattax] #1701415
11/24/14 01:05 AM
11/24/14 01:05 AM
NY NY
3
340duster340 Offline
NY NY
i would leave re-arching off the table. if you are going to spend any money, it might as well be towards a new set of springs. if you have the time and patience and can get another set of used springs super cheap that might work OK. but all in all a new set of springs is the way to go. i have bought 3 sets of springs from ESPO, i am sure the others are fine too. OEM mopar springs sit almost flat for a stock ride. this is because the spring will have the least amount of "sway" around turns.
Re: Where to purchase leaf springs? [Re: 340duster340] #1701416
11/24/14 01:19 PM
11/24/14 01:19 PM
None
71rm23 Offline
71rm23  Offline
None
I agree. BTW- I have a set of Mopar Performance springs Ill sell ya Randy. Didnt use them and are brand new since I went with Spring n Things.
Re: Where to purchase leaf springs? [Re: 71rm23] #1701417
11/24/14 02:57 PM
11/24/14 02:57 PM
france
jose jones Offline
jose jones  Offline
france
I just bought new springs at the local Chrysler-Dodge dealer for a Big Block B-body. Mopar Performance ( or whatever they are now called) still sells them for a little over $100 each. Check your local dealer see if they still sell A body springs
Re: Where to purchase leaf springs? [Re: jose jones] #1701418
11/24/14 05:19 PM
11/24/14 05:19 PM
Corpus Christi, TX
shanker Offline
shanker  Offline
Corpus Christi, TX
That, or if you have an Amazon Prime account, just find the Mopar Performance part # you want, do a search for it, and more than likely it'll be in the 115 to 125 range with free two day shipping....i just bought some springs for my Coronet 3 weeks ago from Amazon... they were 117 each and got free 2 day shipping
The Federal Government has not yet learned that you cannot legislate morality 1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23 1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55 1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91 1975 Duster 360 VS29L5 Daily Driver
Re: Where to purchase leaf springs? [Re: shanker] #1701419
11/24/14 06:06 PM
11/24/14 06:06 PM
Dixie Offline OP
Dixie  Offline OP
Thanks guys. rm, I'll pm you.
