Re: Where to purchase leaf springs?
[Re: Dixie]
#1701393
11/21/14 01:56 AM
11/21/14 01:56 AM
RapidRobert
JR spring (jcwhitney of chicago). EDIT A (very likely) cheaper alt would be to dissassemble em & have a local spring shop rearch the main leaf(s) then you reassemble. Measure the bumper height to ground right now then jack it up till you get the height you want then measure the difference & give that number to the shop. MORE EDIT If you do order tailor made ones get em with 1" more arch (height) than stock
[Re: Dixie]
#1701396
11/21/14 10:24 AM
11/21/14 10:24 AM
Posts: 821 On the open road
Hrtbkr
On the open road
Here's a second for Springs & Things . I had a pair of springs re-arched by a local spring shop and it only lasted a year.
While outside on the turnpike
They got this new hit tune
Where thrills become as cheap as gas
And gas as cheap as thrills
[Re: TJP]
#1701400
11/21/14 03:56 PM
11/21/14 03:56 PM
Posts: 21,070 Niles , Ohio
therocks
Niles , Ohio
Do you have a spring shop around?I got a pair from local spring shop for my 57 that were on their shelf.Mine were totall broke.Cast me 200 bucks.My kid had them rearch his 62s and add a leaf and was like 120.They are still better than a new spring and been on for 15 years.Rocky
Chrysler Firepower
[Re: Dixie]
#1701401
11/21/14 05:59 PM
11/21/14 05:59 PM
Posts: 5,388 Pikes Peak Country
TC@HP2
Pikes Peak Country
He's on a high school budget, so I'm looking for bang for the buck here.
Thanks! Randy
Well, I'd ask if you are sure they need replaced, first. I've seen many guys think a mopar spring set should have a nice arch to them and they replace their "worn out" springs only to find the replacements sit nearly as flat. Mopar sprigns are designed to only have a couple of inches of arch to them when installed.
If they really are worn, get a set from the junkyard, cut the eyes off the main leaf to sit just under the eyes of his leaf spring pack, install in his pack. Results in a slight lift with a step up in rate. Net cost may be around $10-20.
[Re: poorboy]
#1701403
11/21/14 08:35 PM
11/21/14 08:35 PM
RapidRobert
Compress the spring on either side of the middle bolt with a pair of C clamps then remove the nut with a nut cracker. Most times the nut is rusted and or the threads are fubared & if you try to uncrew the nut you'll snap the shaft & that is a special bolt. Chase the threads & a new grade 8 nut loctited & that situation is dealt with
[Re: 383man]
#1701406
11/23/14 02:01 PM
11/23/14 02:01 PM
Posts: 2,336 Ball Ground, Georgia
Dixie
Good stuff guys, thanks. The reason I think it needs new springs is they were sagging pretty bad when I got it. I put helpers on it, and it did help for awhile. I've noticed while driving it recently, that when it hits a bump with more than one person in it, the rear tires scrape. It has new shocks, so I'm thinking the springs are giving a too little much bounce in the rear. $250/pr for a set of springs aren't in his budget. So, it'll just have to scrape for awhile.
I will check with a local shop on re-arching them. That might be the way to go. Finding a set in a junkyard these days maybe be hard to do, but that's a thought too.
Attached is a pic of it at a cruise-in this past summer. I think it has a pretty good stance. It was originally a slant 6 car, so the helpers did raise it a bit in the rear.
[Re: beatgoeson]
#1701410
11/23/14 06:42 PM
11/23/14 06:42 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
That is a sweet looking car. I remember these cars doing what you describe back in the 70's. It's more about the over size tires than wore out springs. That's why those hated long shackles and air shocks were used. Don't go that route. I don't think you are gonna find 10 to 20 dollar springs in any junk yard either. I would add a leaf and, or get yours redone. Talk to local hot rodders to find a good shop. Maybe a slightly narrower or shorter tire might help, but it won't look as good...
I have mechanical Aptitude. I can screw up anything.
