Tips on making a rear end narrowing jig? #1701361
11/21/14 01:06 AM
11/21/14 01:06 AM
Morrow, OH
markz528 Online content OP
markz528  Online Content OP
Morrow, OH
Need to narrow a 8 3/4. Have a good ground heavy duty shaft to use.
Looking for tips/feedback on how you all made the bushings for the third member and the housing ends. In particular, looking for the clearances between the shaft and the bushings and the clearance to the housing ends.
Does anyone have any pictures?
In addition, any tips would be appreciated on the sequence and precautions to minimize warping. Need to weld the perches on along with the back brace.
Re: Tips on making a rear end narrowing jig? [Re: markz528] #1701362
11/21/14 01:17 AM
11/21/14 01:17 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I just used the custom Google search on the top of this page and found everything I ever wanted to know about narrowing an 8 3/4 Mopar rear using a home built jig.
I just typed in "rear end jig"
Gus
64 Plymouth Savoy
Dana 60
Re: Tips on making a rear end narrowing jig? [Re: fourgearsavoy] #1701363
11/21/14 02:43 AM
11/21/14 02:43 AM
Canada
onig Offline
onig  Offline
Canada
On mine, a few thousands of an inch between the shaft and pucks that go in the ends and carrier. If they are to loose one or two revolutions of tape to take up the slack. Have done a few and no problems.
69 Dart
Re: Tips on making a rear end narrowing jig? [Re: markz528] #1701364
11/21/14 09:07 AM
11/21/14 09:07 AM
Jerry Kathe Offline
Jerry Kathe  Offline
Im a welder/machinist by trade but I still purchased my tooling, however I needed tooling for all brands. For your purpose I understand your approach. IMO; machine the adaptors the same OD as the carrier and axle races and the ID to plus .001 - .0015 of the alignment bar.
Welding....this is where it gets tricky....for the order, weld the back brace first then the pads then the ends.
Mig or Tig dictates alot about the process.
Just take your time and skip around allowing ample cool time is about all I can say...this is where experience cant really be clearly explained.
Re: Tips on making a rear end narrowing jig? [Re: markz528] #1701365
11/21/14 12:23 PM
11/21/14 12:23 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Jig at pic #47
Pucks are easy to source these are Mittler?
https://board.moparts.org/ubbthreads/show...part=1&vc=1
Re: Tips on making a rear end narrowing jig? [Re: jcc] #1701366
11/21/14 01:03 PM
11/21/14 01:03 PM
Cincinnati, Ohio
d7cook Offline
d7cook  Offline
Cincinnati, Ohio
Like someone else said weld the ends last.
My friend made us a jig. Once you have the bar the donuts are easy. I think he used a Mark Williams catalog to give him all the bearing dimensions on every combination we would weld and he made all donuts we would ever need.
1967 Coronet, 1989 Daytona tube chassis. Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT. -Banned for life from V8Buick.com-
Re: Tips on making a rear end narrowing jig? [Re: d7cook] #1701367
11/21/14 03:45 PM
11/21/14 03:45 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
I got the bar first and then used the outer bearing races for the dimensions to lathe the donuts for each rear end.
Re: Tips on making a rear end narrowing jig? [Re: d7cook] #1701368
11/21/14 03:52 PM
11/21/14 03:52 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Hard to beat this for cost. He has a bunch of stuff for all types of rears, 8.75, Dana, etc.
http://www.ebay.com/itm/Rearend-Narrowin...=item4ac9986473
Re: Tips on making a rear end narrowing jig? [Re: RobX4406] #1701369
11/21/14 05:36 PM
11/21/14 05:36 PM
Jerry Kathe Offline
Jerry Kathe  Offline
Thats the exact source I used. Time one buys the raw material and machines all the features, it doesn't make sence to stand in front of a manual lathe doing all of that. I can make denario quicker doing other things.
Not saying thats true for everyone, but it was for me.
Re: Tips on making a rear end narrowing jig? [Re: RobX4406] #1701370
11/21/14 07:31 PM
11/21/14 07:31 PM
Cincinnati, Ohio
d7cook Offline
d7cook  Offline
Cincinnati, Ohio
We used a much larger shaft diameter. Not sure how much it matters.
Also I always slide a piece of exhaust pipe over the shaft when welding the ends to keep any splatter off the shaft.
Re: Tips on making a rear end narrowing jig? [Re: Jerry Kathe] #1701371
11/21/14 07:57 PM
11/21/14 07:57 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
I went the MakeMyOwn-way, but I agree those $100 pucks are the way to go.
Been using this axle for about 3 years on my daily driver.
Re: Tips on making a rear end narrowing jig? [Re: BigBlockMopar] #1701372
11/21/14 08:25 PM
11/21/14 08:25 PM
Q
Quicktree Offline
Quicktree  Offline
Q
where do you get the shafts?
Re: Tips on making a rear end narrowing jig? [Re: Quicktree] #1701373
11/21/14 11:57 PM
11/21/14 11:57 PM
Jerry Kathe Offline
Jerry Kathe  Offline
I just rechecked this thread and the Ebay source posted above is not the one I used. The kit I purchased came with the 65” alignment bar and 12” carrier set up bar. All of the adapters were made of steel not aluminum. The housing end retainer's also use a thumb set screw and not a pinch bolt. I also remember it also came from somewhere in Texas. I looked in my Ebay transactions and couldn’t find them. Seems to me it was around 2005 when I purchased this stuff and it cost around 350.00 plus shipping for everything.
I have done a boatload of 9” ford stuff(all sizes of big and small carier and axle bearings) and several Dana’s but only a couple of 8.75 mopars and it has worked great. I also got the Olds stuff since Lamb engineering uses that size housing end on their stuff. I will keep looking and if I find the source I will repost. Sorry for the confusion.
Re: Tips on making a rear end narrowing jig? [Re: Jerry Kathe] #1701374
11/23/14 01:51 AM
11/23/14 01:51 AM
Morrow, OH
Morrow, OH
Thanks for all the responses!
That is very close to what I was planning on. Looks like the nominal outside diameter of the carrier bearing races is 3.2650 so that is what I will target for that donut, and I will measure the ID of the new housing ends and subtract 0.0005 to 0.0010 inches.
For the ID holes, I was planning on 0.002 inches clearance on the carrier donuts and 0.001 inches on the housing end donuts.
Sound reasonable?
We really would like to tack the pads on before we weld the rear brace. Is that a big or minor risk? Will the housing real twist enough to make the pad location an issue?
I am using a 2 inch bar, and really want to custom make my own donuts. I don't know what clearances the ones being sold use, and I am not too keen on their design.
I am planning on miging the rear brace and tiging the pads and housing ends. Does that make sense?
Re: Tips on making a rear end narrowing jig? [Re: markz528] #1701375
11/23/14 11:33 AM
11/23/14 11:33 AM
Jerry Kathe Offline
Jerry Kathe  Offline
For the ID holes, I was planning on 0.002 inches clearanceon the carrier donuts and 0.001 inches on the housing end donuts.
Sound reasonable? Yep. Just make sure that you also
maintain concentricity with ID/OD when machining the
adaptors - just as important as the tolerance itself.
issue? I see nothing wrong with that, could make it easier to assure ubolt clearance.
design.
and housing ends. Does that make sense? Sure - nothing wrong with that.
Re: Tips on making a rear end narrowing jig? [Re: markz528] #1701376
11/23/14 01:36 PM
11/23/14 01:36 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
"I am planning on miging the rear brace and tiging the pads and housing ends. Does that make sense?"
IMO, Not really, tigging compared to mig, will put a lot of heat into the rear, ie distortion, and take a lot of time.
Re: Tips on making a rear end narrowing jig? [Re: jcc] #1701377
11/23/14 03:04 PM
11/23/14 03:04 PM
Jerry Kathe Offline
Jerry Kathe  Offline
Actually you have that backwards. You can control the heat with a tig and still achieve fusion and penetration. With a mig the heat has to balance the feed.....moving faster will just reduce penetration. Tig is slower...but not a ton slower.
Re: Tips on making a rear end narrowing jig? [Re: Jerry Kathe] #1701378
11/23/14 05:42 PM
11/23/14 05:42 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
We still disagree on the end result for the OP.
Re: Tips on making a rear end narrowing jig? [Re: jcc] #1701379
12/07/14 01:37 AM
12/07/14 01:37 AM
Morrow, OH
Morrow, OH
Well I got the bushings done. Came out good - loosest fit is around 0.002 inches on the carrier donuts - the ends are tighter and feel real nice on the shaft.
As soon as the rear housing comes back from getting cleaned gonna give it a whirl!
Re: Tips on making a rear end narrowing jig? [Re: Quicktree] #1701380
12/07/14 02:18 AM
12/07/14 02:18 AM
MR_P_BODY Offline
MR_P_BODY  Offline
When I made my set up I had a 6' length of 1.250 hard
ground shaft laying around work that I used... I spun
up all the pucks out of alum.. everything has .0015
clearance
EDIT
work your way outward.. ends are last and if you
can run the back brace right out to the ends
