Hemi Rockers (Dick Landy set) #1701310
11/20/14 09:27 PM
11/20/14 09:27 PM
USA
Suregrip391 Online content OP
Suregrip391  Online Content OP
USA
I just wanted to know if these Dick Landy Roller rocker assemblies can be used on a set of aluminum mopar performance cylinder heads in place of a set of stock rocker assemblies? The engine would be a 426/472 stroker hemi. Are these overkill or a good choice without any special mods? Do you need any special oiling like thru the pushrods too? Thanks guys...
Re: Hemi Rockers (Dick Landy set) [Re: Suregrip391] #1701311
11/20/14 09:29 PM
11/20/14 09:29 PM
USA
USA
Also will they fit under stock original black wrinkle finish hemi valve covers?
Re: Hemi Rockers (Dick Landy set) [Re: Suregrip391] #1701312
11/20/14 10:14 PM
11/20/14 10:14 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
These are the same rockers that came on the alum headed crate engines....so yes they will work fine.
With a large cam, converting to pushrod oiling or improving the oiling is needed to prevent burning pushrod ends.
I'm using cast alum Mopar covers so dont know for sure but I think these will fit under stock covers.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Hemi Rockers (Dick Landy set) [Re: HemiRick] #1701313
11/20/14 10:22 PM
11/20/14 10:22 PM
USA
USA
I think the cam lift is .557 intake/.540 exh , it's a solid cam, these really came on crate motors? Dick landy stainless rollers? What is the difference between a set using "collars" on the shafts, and others use springs? Is one preferred over the other?
Re: Hemi Rockers (Dick Landy set) [Re: Suregrip391] #1701314
11/20/14 10:55 PM
11/20/14 10:55 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
I had these on my 1970 434 Hemi with iron heads & stock black crinkle covers & had to dimple them a bit where the exhaust rockers hit. Only had a 574 lift solid flat tappet cam & never had pushrod issues.
