2002 Ram Van charging system issue #1701186
11/20/14 03:13 PM
11/20/14 03:13 PM
Detroit, MI
GetAwayDriver Offline OP
Detroit, MI
A friend of mine in another state is looking at a van with an "intermittent" charging issue. The guy selling it claims to have cleaned all the grounds and connections, then changed the alternator. Now he's ready to try a new PCM on someone's recommendation.
I'm not real familar with this era's mix of old/new parts, but I assume the voltage regulator is within the PCM. Then again, an intermittent problem sure doesn't sound like a PCM issue.
Any suggestions beyond all electrical connections and perhaps a new battery?
Re: 2002 Ram Van charging system issue [Re: GetAwayDriver] #1701187
11/20/14 03:21 PM
11/20/14 03:21 PM
Andrewh Offline
Andrewh  Offline
it is built in to the pcm.
a cheap fix is to use a 70's era vr and just clip the wires from the pcm instead of replacing it.
12 bucks instead of 150.
Re: 2002 Ram Van charging system issue [Re: Andrewh] #1701188
11/20/14 03:36 PM
11/20/14 03:36 PM
Detroit, MI
Detroit, MI
That's good thinkin'. I'll pass this link along. Thanks
