Street/Strip A-body - Best Clutch-Bell-Flywheel Combo?
#1701122
11/20/14 12:09 PM
11/20/14 12:09 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
I'm looking at starting from scratch on a combo for a street/strip Duster build (will end up being about 3,400lbs). 340 resto block, stroked to 440 cubes, 550-600HP, TTI 17/8" W2 headers, stock power steering, suspension, etc. Will be running M/T Street ET tires. What flywheel, clutch, bell housing would you guys recommend for this combo? It will be getting a lot of street duty, I want something stout that fits, and still drivable in traffic.
Re: Street/Strip A-body - Best Clutch-Bell-Flywheel Combo?
[Re: ScottSmith_Harms]
#1701125
11/21/14 12:49 AM
11/21/14 12:49 AM
Posts: 4,013 South Park, Pa.
68LAR
South Park, Pa.
I'm looking at starting from scratch on a combo for a street/strip Duster build (will end up being about 3,400lbs). 340 resto block, stroked to 440 cubes, 550-600HP, TTI 2.25" headers, stock power steering, suspension, etc. Will be running M/T Street ET tires. What flywheel, clutch, bell housing would you guys recommend for this combo? It will be getting a lot of street duty, I want something stout that fits, and still drivable in traffic. Quote:
Here's my suggestion: 20 lb SFI flywheel Centerforce dual Friction pressure plate and disk.
This is the way I'd go. Actually went this way, but with a big block stroker instead of a small block stroker.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
[Re: blue_stocker]
#1701129
11/21/14 09:59 PM
11/21/14 09:59 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
as far as bellhousing, nothing short of scattershield unless you drive it like an old lady. your feet are more important!
Hell Hath No Fury Like Mine
