Re: Master Cylinder Color
[Re: Kern Dog]
#1701070
11/20/14 05:40 PM
11/20/14 05:40 PM
Posts: 6,224 JERSEY
RJS
JERSEY
That totally depends on the car, the brake package and the year.
Best answer so far!!!! Ron
[Re: dart4forte]
#1701079
11/21/14 02:50 AM
11/21/14 02:50 AM
Posts: 28 NH
Bee Nice
NH
Charger, Road Runner, & Super Bee Authentic Restoration Guide written by Paul Herd page 95 states, Master Cylinders 1968 "The cylinder itself should be painted cast-iron gray to simulate the fresh-cast look, and the cover and hold down clamp should have cadmium gold appearance. Page 95 goes onto state The Federally-Mandated dual circuit cylinder first appeared on 1967 models. Both 67 & 68 used Part number 2808599. Chrysler Muscle Car Parts Interchange Manual written by Paul Herd page 85 shows part number 2808599 applicable to 1967-69 Barracuda, Fury, Monaco, Newport, New Yorker, and Polara. 1967 - 68 Belvedere, Charger, and Coronet, with drum brakes. Used in both power and non-power assisted applications.
[Re: Bee Nice]
#1701081
11/21/14 03:19 AM
11/21/14 03:19 AM
Posts: 8,341 Crook County, ILL
Mastershake340
Crook County, ILL
2808599 is a drum brake master cylinder. 67-70 drum brake Mopars all used the same master cylinder and it had the bolt on style cap. Generally accepted to be cast iron with plated cap, though I have NOS examples that have the body E coated black with a plated cap. The OP asked about a disc brake master cylinder. All the Mopar disc brake master cylinders from '67-'70 were painted gloss black except the flange and the area by the outlets where protective plugs were installed prior to painting. Here is an NOS assembly line '67-'70 A body manual disc brake master cylinder casting number 2225541 date coded 212th day of '69. Interestingly has a splotch of white paint on the front of the bore area of the casting.
[Re: Mastershake340]
#1701082
11/21/14 03:26 AM
11/21/14 03:26 AM
Posts: 16,133 Mesa, Arizona
dart4forte
Mesa, Arizona
I have the 541. So you say black is the color. Mine is date coded late 67
[Re: dart4forte]
#1701085
11/21/14 12:40 PM
11/21/14 12:40 PM
Posts: 4,783 Ontario, Canada
mccannix
Ontario, Canada
I can live with that. Looks like that's a book I should get.
I myself would not use that book for reference restoration.
[Re: DPelletier]
#1701087
11/21/14 04:50 PM
11/21/14 04:50 PM
Posts: 6,224 JERSEY
RJS
JERSEY
There are lots of mistakes in that book.
Ditto Ron
[Re: Cab_Burge]
#1701089
11/21/14 08:53 PM
11/21/14 08:53 PM
dart4forte
Mesa, Arizona
Ditto Ron
There are lots of mistakes in every car book article I've ever seen or read I own a 1969 Dart GTS 383 4 speed car without power brakes, it has the stock Kelsey Hayes front disc brakes on it, this is the M.C. that was on it when I bought it in the early 1990s,(this car was sold at Saddleback dodge in Orange County, CA in late 1968) it works very well, it doesn't seem to have a residual valve in the back half of the M.C., the front tires spin as easy as any other front disc brake Mopar I have owned, drivened and worked on or raced
According to themoparman (Wayne) who restores M/Cs you should have M/C 2225541 which has the 1" bore suited for the A body manual and disk brakes. Looks like you have a manual brake M/C. It also looks like someone like orange.
