Correct Color Orange for 440 Engine in a 1970? #1700994
11/19/14 10:51 PM
11/19/14 10:51 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
What is the correct color orange paint that I should be using on a 440 HP engine for my 1970 Dodge Coronet R/T? Is it street Hemi orange?
Thank you in advance!
Vinny
Re: Correct Color Orange for 440 Engine in a 1970? [Re: vinnyd76] #1700995
11/19/14 11:03 PM
11/19/14 11:03 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
I'm getting good life out of Mopar 'Street Hemi' rattle-can orange over a primed block...
If you want to go beyond that, Badalson addressed 'orange' engine color in the past...
I believe in MCG...
Re: Correct Color Orange for 440 Engine in a 1970? [Re: RSNOMO] #1700996
11/20/14 11:32 AM
11/20/14 11:32 AM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
Use the Plastikote #226, it works great!!!
Admiration For Multiple Carburetor Vehicles...
Re: Correct Color Orange for 440 Engine in a 1970? [Re: vinnyd76] #1700997
11/20/14 12:03 PM
11/20/14 12:03 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
I use Dupli-color De1652 Chrysler Hemi Orange. Autozone or O'Reilly's carries it.
Re: Correct Color Orange for 440 Engine in a 1970? [Re: Triggerfish] #1700998
11/20/14 12:05 PM
11/20/14 12:05 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
DE1652 on my 70 383..
Re: Correct Color Orange for 440 Engine in a 1970? [Re: Triggerfish] #1700999
11/20/14 01:02 PM
11/20/14 01:02 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Plastikote if you are using spray bomb, Badalson's if you are shooting from a gun and are wanting factory correct.
Plastikote has more shine than original but it looks great and holds up good.
Here is an engine with Badalson's paint
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: Correct Color Orange for 440 Engine in a 1970? [Re: MOPARMIKE69] #1701000
11/20/14 01:34 PM
11/20/14 01:34 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Another vote for Plastikote 226. Looks very good and is oh so easy to touch up.
I find sheen is dependant a bit on how you apply it and I've certainly seen many spray guy jobs that were far too shiny.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Correct Color Orange for 440 Engine in a 1970? [Re: RSNOMO] #1701001
12/19/14 06:23 PM
12/19/14 06:23 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Anyone use Plasti-Kote or Dupli-Color Primer?
Re: Correct Color Orange for 440 Engine in a 1970? [Re: vinnyd76] #1701002
12/19/14 10:05 PM
12/19/14 10:05 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I like the Plasti-Kote...primer and orange paint.It holds up MUCH better than Dupli Color and wont fade over time.
Nautilus Racing-
Re: Correct Color Orange for 440 Engine in a 1970? [Re: Chris2581] #1701003
12/19/14 10:39 PM
12/19/14 10:39 PM
IN
ahy Offline
ahy  Offline
IN
I believe the "correct" color is street hemi orange. I used the MP stuff over a primed block ~10 years ago and it has held up pretty well. By some miracle the old spray cans still work for touch up too. That paint gets bashed a lot but did OK for me.
Re: Correct Color Orange for 440 Engine in a 1970? [Re: ahy] #1701004
12/19/14 10:44 PM
12/19/14 10:44 PM
Loganville GA.
K
kdsmith07 Offline
kdsmith07  Offline
K
Loganville GA.
I don't remember seeing plasti-kote anywhere.where do you all get yours?tia
Re: Correct Color Orange for 440 Engine in a 1970? [Re: Triggerfish] #1701005
12/20/14 01:34 AM
12/20/14 01:34 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I used this on the last eng I built here in my 63 and really liked it at first. But it seems to be peeling in small spots sometimes and the paint on the oil pan peels some. I found that if I spray it back on even when its very clean it just dont lay right and seems tp peel and even get small bubbles in it. But if I spray the paint in a lid and use a small brush it goes on much better and stays on better. I never had this problem with any other engines and the orange paint and this is the first time I used the Dupli-Color paint. I really like how it looks and went on but I am not real pleased with how its holding up on my eng. Ron
Re: Correct Color Orange for 440 Engine in a 1970? [Re: 383man] #1701006
12/21/14 07:41 PM
12/21/14 07:41 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
I located Plasti-Kote products on Amazon, it appears all the retailers/distributors in MI have pulled the products and replaced with Dupli-Color products.
Re: Correct Color Orange for 440 Engine in a 1970? [Re: vinnyd76] #1701007
12/21/14 09:04 PM
12/21/14 09:04 PM
Loganville GA.
K
kdsmith07 Offline
kdsmith07  Offline
K
Loganville GA.
thanks vinny,i'll try them
Re: Correct Color Orange for 440 Engine in a 1970? [Re: vinnyd76] #1701008
12/21/14 09:23 PM
12/21/14 09:23 PM
Tennessee
WyleECoyote Offline
WyleECoyote  Offline
Tennessee
Why is Plasti-Kote being pulled from stores???
All 3 stores in the Knoxville, TN area had their Plasti-Kote line pulled out a month ago?
Wile E. Coyote
Super Genius, Lover of FCA US LLC Products
68 Road Runner (440 4-spd), 71 Superbee (383 slap), 71 Charger 500 (383 4-spd wA/C 1of 182), 72 Imperial, 74 Charger SE (440 sunroof), 84 D350 Crew-cab Dually (440), 75 D300 Dually Tandem (318 4-speed)
Re: Correct Color Orange for 440 Engine in a 1970? [Re: 383man] #1701009
12/22/14 12:37 AM
12/22/14 12:37 AM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
Ron, I had the same problem with Duplicolor not holding up on my orig valve covers after about a year so made sure I put a couple of primer coats on my new covers before spraying them. Paint seems to be holding up well on them
after a year's time, except for a couple of spots where I tried to clean up
some spilled oil with rubbing alcohol & that really dulled a small area.
Haven't been able to find Plastikote locally, so went with the Duplicolor.
Re: Correct Color Orange for 440 Engine in a 1970? [Re: Triggerfish] #1701010
12/22/14 02:37 PM
12/22/14 02:37 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
I swore by PlastiKote for years until I got a bad can or two. The exterior label on the can changed as well from their original silver and white to blue. Don't know what happened there... BTW I believe Plastikote is really Valspar...also noticed Plastikote disappearing from the shelves in parts stores, being replaced by DupliColor.
Re: Correct Color Orange for 440 Engine in a 1970? [Re: Triggerfish] #1701011
12/23/14 03:46 AM
12/23/14 03:46 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Thanks for the info. Ron
