Re: Correct Color Orange for 440 Engine in a 1970?
[Re: Triggerfish]
#1700999
11/20/14 01:02 PM
11/20/14 01:02 PM
Posts: 2,632 Nashville, TN
MOPARMIKE69
Nashville, TN
Plastikote if you are using spray bomb, Badalson's if you are shooting from a gun and are wanting factory correct. Plastikote has more shine than original but it looks great and holds up good. Here is an engine with Badalson's paint
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
[Re: MOPARMIKE69]
#1701000
11/20/14 01:34 PM
11/20/14 01:34 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
Another vote for Plastikote 226. Looks very good and is oh so easy to touch up. I find sheen is dependant a bit on how you apply it and I've certainly seen many spray guy jobs that were far too shiny. Dave
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: vinnyd76]
#1701002
12/19/14 10:05 PM
12/19/14 10:05 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I like the Plasti-Kote...primer and orange paint.It holds up MUCH better than Dupli Color and wont fade over time.
[Re: Triggerfish]
#1701005
12/20/14 01:34 AM
12/20/14 01:34 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
I use Dupli-color De1652 Chrysler Hemi Orange. Autozone or O'Reilly's carries it.
I used this on the last eng I built here in my 63 and really liked it at first. But it seems to be peeling in small spots sometimes and the paint on the oil pan peels some. I found that if I spray it back on even when its very clean it just dont lay right and seems tp peel and even get small bubbles in it. But if I spray the paint in a lid and use a small brush it goes on much better and stays on better. I never had this problem with any other engines and the orange paint and this is the first time I used the Dupli-Color paint. I really like how it looks and went on but I am not real pleased with how its holding up on my eng. Ron
[Re: vinnyd76]
#1701008
12/21/14 09:23 PM
12/21/14 09:23 PM
Posts: 1,377 Tennessee
WyleECoyote
Tennessee
I located Plasti-Kote products on Amazon, it appears all the retailers/distributors in MI have pulled the products and replaced with Dupli-Color products.
Why is Plasti-Kote being pulled from stores???
All 3 stores in the Knoxville, TN area had their Plasti-Kote line pulled out a month ago?
Wile E. Coyote Super Genius, Lover of FCA US LLC Products ************* 68 Road Runner (440 4-spd), 71 Superbee (383 slap), 71 Charger 500 (383 4-spd wA/C 1of 182), 72 Imperial, 74 Charger SE (440 sunroof), 84 D350 Crew-cab Dually (440), 75 D300 Dually Tandem (318 4-speed)
[Re: Triggerfish]
#1701011
12/23/14 03:46 AM
12/23/14 03:46 AM
383man
Balt. Md
Ron, I had the same problem with Duplicolor not holding up on my orig valve covers after about a year so made sure I put a couple of primer coats on my new covers before spraying them. Paint seems to be holding up well on them after a year's time, except for a couple of spots where I tried to clean up some spilled oil with rubbing alcohol & that really dulled a small area. Haven't been able to find Plastikote locally, so went with the Duplicolor.
Thanks for the info. Ron
