What is this thing on the Coil #1700969
11/19/14 10:36 PM
11/19/14 10:36 PM
Tacoma, Washington USA
Adam71Charger Offline OP
I cant remember what this thing is hooked onto the coil with 1 wire, looks like a capacitor. This is a 1972 318 with a points distributor.
Re: What is this thing on the Coil [Re: Adam71Charger] #1700970
11/19/14 10:39 PM
11/19/14 10:39 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Condenser...
Fer radio interference...
Re: What is this thing on the Coil [Re: Adam71Charger] #1700971
11/19/14 10:41 PM
11/19/14 10:41 PM
NY
clemul Offline
clemul  Offline
NY
It is a radio noise suppression condenser...
Re: What is this thing on the Coil [Re: clemul] #1700972
11/19/14 10:45 PM
11/19/14 10:45 PM
Can it cause ignition problems if it goes bad? Are certain coils designed to work with them, or is it just an add on?
Re: What is this thing on the Coil [Re: Adam71Charger] #1700973
11/19/14 10:49 PM
11/19/14 10:49 PM
& it goes on the positive pri terminal which yours does
Re: What is this thing on the Coil [Re: Adam71Charger] #1700974
11/20/14 12:23 AM
11/20/14 12:23 AM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
Yes it can go bad. In general they get 'leaky" which means they loose capacitance. Which shows up as additional ignition noise in the radio. It does not interfere with ignition operation. BTW, condenser and capacitor are two terms for the same device. Condensor is an archaic term and is used by the automotive industry and 90 year old amateur radio operators.
Craig
Re: What is this thing on the Coil [Re: Adam71Charger] #1700975
11/20/14 12:30 AM
11/20/14 12:30 AM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
Yes, it can definitely go bad and yes it is just an add on for radio noise suppression. The coil doesn't care if it is there or not
1970 Superbird 440-6bbl, auto
1969 Barracuda 340-4bbl, FB Formula S auto
1969 Barracuda 6.1 L Hemi, 5 speed, Convertible
2022 Can Am Spyder RTL
Re: What is this thing on the Coil [Re: clemul] #1700976
11/20/14 12:33 AM
11/20/14 12:33 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Do they make one for the spousal unit?
- Stu Harmon
Re: What is this thing on the Coil [Re: feets] #1700977
11/20/14 12:41 AM
11/20/14 12:41 AM
Kirkland, Washington
Pacnorthcuda Offline
Yes they do, but the most effective one has to be granted by a judge and its very expensive.
Many just put up with the noise.
Re: What is this thing on the Coil [Re: Pacnorthcuda] #1700978
11/20/14 01:38 AM
11/20/14 01:38 AM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Pitiful...
My 43 year-old OEM AM/FM is 'noise-free'...
There are ways...
Re: What is this thing on the Coil [Re: RSNOMO] #1700979
11/20/14 02:31 AM
11/20/14 02:31 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Yes they can go bad. The worst it can do is get so bad it can internally ground out. Had one once many years ago as it was a point car but the condenser grounded out and it would not start. And just about every tech that looked at it before me never even checked it. Ron
Re: What is this thing on the Coil [Re: 383man] #1700980
11/20/14 03:03 PM
11/20/14 03:03 PM
dogdays Offline
dogdays  Offline
Funny, isn't it,in the automotive world a capacitor is called a condenser.
Yes they do go bad and the can type is especially susceptible to age-related failures. Becoming a short is the most common mode.
R.
