Trunk floor install 1968 Road Runner #1700832
11/19/14 01:04 PM
11/19/14 01:04 PM
Allenton Mi
dodgecharger68 Offline OP
Allenton Mi
The trunk pan in my car is bad between the frame rails were water layed over the years from the trunk leaking. I only want to replace the metal that is bad between the rails. The other trunk floor metal is fine. Is it considered exceptable to only replace bad metal. Thanks for your help.
Re: Trunk floor install 1968 Road Runner [Re: dodgecharger68] #1700833
11/19/14 01:38 PM
11/19/14 01:38 PM
Waddell AZ
azblackhemi Offline
azblackhemi  Offline
Waddell AZ
By the time you finish off the seams where you splice it in you might as well put the whole pan in. Not really going to save much time splicing it.
Re: Trunk floor install 1968 Road Runner [Re: dodgecharger68] #1700834
11/19/14 02:01 PM
11/19/14 02:01 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I did one like that a few months back, the rest of the pan was solid and this way I could save the factory spot welds. I'd say the time I saved not drilling out all the spot welds for one from the old floor alone made it worth doing it this way. Then you have to drill tons of holes in the new floor when you replace the whole thing... looking at big picture, it definitely saved me time and I prefer to keep as much original metal as possible.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Trunk floor install 1968 Road Runner [Re: Silver70] #1700835
11/19/14 02:25 PM
11/19/14 02:25 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
I think the extra effort is worth it.
Re: Trunk floor install 1968 Road Runner [Re: dodgecharger68] #1700836
11/19/14 04:11 PM
11/19/14 04:11 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
friend of mine did just that on a Daytona project they have in .
A lot of carefull trimming and trial fitting ,yielded a new pan that no one can tell was ever replaced.
He split it and rewelded it right down the lip pf the frame rail edge. Once ground down you can not tell for the top or bottom.
Plus they didn't have to remove the tail light panel to do it this way.
Re: Trunk floor install 1968 Road Runner [Re: gtx6970] #1700837
11/21/14 03:10 AM
11/21/14 03:10 AM
Southeast PA
5wndwcpe Offline
5wndwcpe  Offline
Southeast PA
Yep, this is how I do them if a whole pan is not required.
1968 GTX hardtop
1968 Sport Satellite Convertible 383/4spd
1933 Plymouth coupe
2002 Ram 2500 oil burner 4x4
2015 Grand Cherokee
2013 Challenger
1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
