Re: Witch bellhousing?
[Re: sshemi]
#1700806
11/19/14 02:02 PM
11/19/14 02:02 PM
Posts: 729 Lebanon,IN
mr2performance
Lebanon,IN
Browell makes one similar to the lakewood, but his quality is by far better. PM me if you need a price. Mike
MR2PERFORMANCE RACE CARS
765 483 9371
Re: Which bellhousing?
[Re: sshemi]
#1700811
11/19/14 10:25 PM
11/19/14 10:25 PM
Posts: 209 Mesa, Arizona
6pak2go
Mesa, Arizona
I have a Quicktime behind my big block and it seems to be a nice piece. The runout was with in spec out of the box, no offset dowels required on my install. I have a 10" McLeod soft-lok and the counter-weights have only .100" clearance to the bell. 10.5" or bigger probably won't work. Make sure your clutch will fit it.
Robert R Mesa, AZ 70 Challenger R/T 440-6 4-Sp Cruiser 67 Barracuda FB 540 4-Sp Strip/Street and Drag Week
[Re: 6pak2go]
#1700812
11/19/14 10:26 PM
11/19/14 10:26 PM
6pak2go
Mesa, Arizona
The supplied Z-bar bracket required strengthening as it bent over under the stress. Added two more gussets, cured the problem. Obviously not an issue with you're hydraulic TB.
