Re: 3.55 to 3.91 or 4.10
[Re: stumpy]
#170072
12/18/08 04:34 PM
12/18/08 04:34 PM
Posts: 7,647 Houston Texas
PAINT IT BLACK
Got a CHIP on my shoulder
Houston Texas
Wow. What a cool site. Thank you. I have thought long and hard about whether or not to go with a Passon OD unit in my Cuda, as well as the Bee, but that site helped me decide that since the Cuda has a 3.91 and all I really save is about 700 RPM at 80 mph (significant, yes, but worth it?), I think I'll just leave it as is. With the Bee, I have to buy new gears anyway, so I'll still go with the OD unit for that one since it'll be nice to have a taller gear in it. If I run a 4.56 in the Bee with the Passon gear set, I'll have a final drive at 80 mph at just about where the Cuda is now - 3,700 RPMs. VERY helpful and cool site!
[Re: coronetkid]
#170078
12/18/08 06:01 PM
12/18/08 06:01 PM
Posts: 3,144 Central NC
gch
Central NC
383 906 heads 850 double pump carb performer rpm intake 3500 stall cam not 100% sure would have to dig out paperwork
It depends on your shift rpm.I think 3.91's are fine for mostly street.4.10's will e.t. better if you can hook but are no fun on the street.
[Re: gch]
#170079
12/18/08 08:01 PM
12/18/08 08:01 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
[I think 3.91's are fine for mostly street.4.10's will e.t. better if you can hook but are no fun on the street.
Not much RPM difference between 3.91s and 4.10s. If 4.10s are no fun, then 3.91s shouldnt be either.
I run 4.30s with a 28 inch tall tire and it doesnt bother me at all.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: PAINT IT BLACK]
#170080
12/18/08 08:04 PM
12/18/08 08:04 PM
Posts: 3,616 Riverside, Ca
G_bob
Riverside, Ca
I've got 3.91's in the challenger with a 28" tall tire. I put a gearvendors unit on it and it is night and day difference running down the freeway. Well worth it for me. My
[Re: 1_WILD_RT]
#170081
12/18/08 08:29 PM
12/18/08 08:29 PM
Posts: 4,316 Prospect, PA
BSB67
Prospect, PA
The limiting factor is gonna be traction...4.10 is a fun gear but you'll need to feather it out of the hole or you'll just blow the tires off...
If you are traction limited on the launch now, you will not see much difference. What is your 60', et and mph?
[Re: RapidRobert]
#170086
12/19/08 08:38 AM
12/19/08 08:38 AM
looking for better 1/4 mile time
4.10
3.91's are ok but if you want a stop light burner, go lower!! i have 4.30's and love them!! i'll drive on freeways but limit my speed to 65 mph. that puts me at 3500 or so
