318 302 heads #1700459
11/18/14 07:48 PM
11/18/14 07:48 PM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
Is it necessary to plug the holes under exhaust ports they have a ton of miles on them and they look to be plugged up with carbon? Customer is putting headers on......truck application. Thanks in advance Moparts.
Moparlee
Re: 318 302 heads [Re: Robbins] #1700460
11/18/14 07:57 PM
11/18/14 07:57 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
You can easily run a tap into the holes and plug them with allen head set screws.
Re: 318 302 heads [Re: burdar] #1700461
11/18/14 08:29 PM
11/18/14 08:29 PM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
Ya...done that with some 86 360 heads with the same style headers.....but I thought that I seen where someone got away with not doing it. Anyways thanks for the quick reply.
Moparlee
Re: 318 302 heads [Re: Robbins] #1700462
11/18/14 08:59 PM
11/18/14 08:59 PM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
Does anybody know what size tap and plugs you need
for this project?
Moparlee
Re: 318 302 heads [Re: Robbins] #1700463
11/18/14 09:07 PM
11/18/14 09:07 PM
13/64 and 1/4-20 iirc. EDIT 13/64 for the drill bit and 1/4-20 for the tap and plug. To plug it a 1/4 coarse thread stud with the female recess for an allen wrench to screw it in works good. Just pick the right length
Re: 318 302 heads [Re: RapidRobert] #1700464
11/18/14 09:31 PM
11/18/14 09:31 PM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
Sweet.....thanks.
Moparlee
Re: 318 302 heads [Re: Robbins] #1700465
11/19/14 02:26 PM
11/19/14 02:26 PM
dogdays Offline
dogdays  Offline
My 302s I did that, broke a Greenlee tap off in one hole, so be careful. Plugged all the other holes with some short bolts I had found in a parts drawer, plugged the "tap hole" with JB Weld.
10,000 miles later all are still plugged.
BTW, I used a rotary cutoff wheel to take off the bolt heads. May be cheaper than setscrews.
R.
