318 302 heads
#1700459
11/18/14 07:48 PM
11/18/14 07:48 PM
Posts: 4,920 Joplin, MO USA
Robbins
Joplin, MO USA
Is it necessary to plug the holes under exhaust ports they have a ton of miles on them and they look to be plugged up with carbon? Customer is putting headers on......truck application. Thanks in advance Moparts.
Moparlee
Re: 318 302 heads
[Re: burdar]
#1700461
11/18/14 08:29 PM
11/18/14 08:29 PM
Robbins
Joplin, MO USA
Ya...done that with some 86 360 heads with the same style headers.....but I thought that I seen where someone got away with not doing it. Anyways thanks for the quick reply.
Moparlee
Re: 318 302 heads
[Re: Robbins]
#1700462
11/18/14 08:59 PM
11/18/14 08:59 PM
Robbins
Joplin, MO USA
Does anybody know what size tap and plugs you need for this project?
Moparlee
Re: 318 302 heads
[Re: Robbins]
#1700463
11/18/14 09:07 PM
11/18/14 09:07 PM
RapidRobert
13/64 and 1/4-20 iirc. EDIT 13/64 for the drill bit and 1/4-20 for the tap and plug. To plug it a 1/4 coarse thread stud with the female recess for an allen wrench to screw it in works good. Just pick the right length
