Re: anyone running a d1sc supercharger in their mopar?
[Re: Jerry]
#1700353
11/18/14 05:21 PM
11/18/14 05:21 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
I am new to the SuperCharger engines,but mine has an A&A Vortec SuperCharger on a LS3 engine and has a intercooler.Even if a intercooler was not needed I think I would run one to be on the safe side.I would read the instructions and try to follow them as close as possible. As for the 4-speed manual trans it will work great and be a blast driving it on the street.Mine has a manual 6 speed and for street driving an maybe a little track time & street racing there is no way I would change it over to a Automatic. I would use all MSD dist.,coil & MSD box with the upgrade as well.And after you get it going the only thing left you will need is a set of DOT Drag Radials!
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: Jerry]
#1700358
11/18/14 07:33 PM
11/18/14 07:33 PM
MRMOPAR622
Sweet Home Alabama
are you running an air to air intercooler or an air to water intercooler?
It is a fairly large air-air intercooler mounted in front of the radiator.It has 10.7-1 CR and runs on 93 octane pump gas.
[Re: Jerry]
#1700362
11/19/14 02:09 AM
11/19/14 02:09 AM
MRMOPAR622
Sweet Home Alabama
I will count them tomorrow and let you know.
[Re: MRMOPAR622]
#1700363
11/19/14 02:59 AM
11/19/14 02:59 AM
Posts: 305 5th and plum
redmist
5th and plum
This is relavent to my interests... As I just so happen to have a Procharger D1 that is going in a Fuel Injected 440 that is similar build. I need brackets, and pulleys!!!! I also have CNC equipment to use, Two Horizontals, two verticals, and two 8-axis turn-Mills. My goal is to keep the power steering.
