Re: Lots of shock questions lately
[Re: sixpackgut]
#1700033
12/23/14 11:48 PM
12/23/14 11:48 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
I have the same dilemma. I have Rancho 9 ways on the back and the Caltrac 90/10 on the front. My D50 will hook on the hit pull the wheels then spin badly. When it was hooking it would carry the tires about 45-50 ft. then the front would come down hard and unload the rears. I am thinking about putting the stock front shocks back on it. This is a picture of the landing.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: sixpackgut]
#1700038
12/24/14 12:46 AM
12/24/14 12:46 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I like that reason better. But I would tie it down more and do rears.
Exactly what one of my 4 second fast friends said to do
Didnt you say you have poly bushings in the front.. they can cause issues if they bind up.. how much travel do you have
I ment huge poly bump stops. If i said bushings, i mispoke. I also just asked a simple question and also said my car makes it down the track nearly every time with 6 year old radials although i do realize my 60 is only 1.41-42
Ok
[Re: Monte_Smith]
#1700040
12/24/14 05:36 AM
12/24/14 05:36 AM
Quicktree
I DON'T like 3 ways on the front of anything.........I don't care how good guys think they work. If the front doesn't work, the rear never will...........so that is my answer.........FRONTS
Monte
BAM
[Re: D-50]
#1700041
12/24/14 05:38 AM
12/24/14 05:38 AM
Quicktree
in your case you need to replace both front and back.
[Re: D-50]
#1700043
12/24/14 11:43 AM
12/24/14 11:43 AM
Posts: 1,969 Chandler, AZ
Duner
Chandler, AZ
That's exactly what mine was doing with the Caltrac 90/10s on it. I tried some QA1 single adjustables and got it to at least not land the front tires and start spinning the rears - but I haven't got it to hook as well at the hit yet. After some review - MY problem may very well be old slicks. I'll have to buy a new set and start over.
[Re: D-50]
#1700046
12/24/14 03:16 PM
12/24/14 03:16 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Stock shocks will be WORSE, much worse. You MUST control the RATE of the rise, or it tops the suspension and spins the tires.
I have seen your truck run. Fairly light, not huge power and a big tire. It dead sticks the tire and jerks the front up very quickly. Needs a better shock to control the front on launch and landing
Monte
[Re: Quicktree]
#1700047
12/24/14 03:43 PM
12/24/14 03:43 PM
Posts: 456 corpus christi tex
Cheatham
corpus christi tex
Monte
BAM
Santhuffs is 25mins from me and i spoke to him a while back he said the same thing, he rather see guys use a high quaility shock with travel up front and if you have to go cheap then do it on the rear shocks not the fronts
[Re: Cheatham]
#1700048
12/24/14 04:14 PM
12/24/14 04:14 PM
Posts: 526 NC
barracuda man
NC
The money i have spent on the front end in the last 3 months.'Trying to get the abody notchback barracuda to hook consistent.last time out with the car i lost in the 5 round.had him .15 on the tree.car spun tires .2 in 60 ft.car did not run #.I told myself i got to fix this car.lost to a mustang. I've been eyeing the tube chassie duster $$$ Drag race Torsion bars $325 da front shocks $400 fiberglass hood $525 strange disc front brake kit $730 upper control arms $367
[Re: sixpackgut]
#1700050
12/24/14 06:26 PM
12/24/14 06:26 PM
Quicktree
Monte
BAM
Nothing warms my heart more than quicktree and Monte agreeing on something during the winter, then again they both live in the south
I agree with Monte on 99.9% of everything. only thing I have never been able to convince him of is pinion angle. but im still working on that and by the way he is way more smarter than I am.
