Re: Lots of shock questions lately
[Re: Monte_Smith]
#1699991
11/19/14 03:22 PM
11/19/14 03:22 PM
Posts: 10,038 MN
JERICOGTX
MN
So how much does a set of 4 Santhuffs cost? Rear coilovers, and fronts for stock suspension. Their web site isn't much help.
Jeff
69 GTX
68 Road Runner
[Re: RT540]
#1699993
11/19/14 09:36 PM
11/19/14 09:36 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
You guys looking for shocks and prices just need to call Mark Roth if you are interested in Santhuffs and Mark Menscer or AFCO direct if that is your choice.
The reason is........a shock is NOT a shock. Even in GOOD D/A shocks, the intended purpose of the car comes into play. We call most GOOD race shocks "double adjustable" but shocks really have 4 adjustments that can be made to them. There is a high and low speed rebound and a high and low speed extension. Since drag cars don't see varying track conditions like a round track car, having all 4 externally adjustable is not needed...........BUT, the power level and type suspension used, will dictate where in the valving the low speed takes over from the high.
High speed valving is defined as hitting the shock hard and fast, such as at launch. Low speed is usually down track to absorb bumps. Since shocks are very sensitive to velocity, the type suspension and power level greatly comes into play on choosing a valving. Power and a violent suspension setup, like a ladder bar, will require the high speed to be very sensitive, very quick, to control the housing. Lesser power and lesser aggressive suspension, like leafs, will change the transition point in the valving.
All this is why a "serious" guy should not just pick up the phone and order some shocks from Jegs
Monte
[Re: JERICOGTX]
#1699995
11/20/14 08:16 AM
11/20/14 08:16 AM
Posts: 729 Lebanon,IN
mr2performance
Lebanon,IN
The rears retail for $1210 a pair and the fronts are $1000 retail. I can save you quite a bit of money over those prices though. Mike
MR2PERFORMANCE RACE CARS
765 483 9371
[Re: Monte_Smith]
#1699998
11/20/14 01:35 PM
11/20/14 01:35 PM
Posts: 625 Indianapolis In. usa
Quickrunner
Monte
Best explanation I have seen on this board! People dont realize how involved every aspect of a purpose build drag car really is, or should be! Hats off to you Monte
05 Ram 1500 Daytona package 71 Demon Gen3 hemi drag radial project
Missin' my 9 second 70 runner!
[Re: moparniac]
#1700002
11/22/14 11:01 PM
11/22/14 11:01 PM
Posts: 39 Lancaster, Pennsylvania
Sweigart1022
If anybody is interested or ever has questions about Penske Racing Shocks let me know. I split my time currently between the drag race and NASCAR shocks at Penske. Our shocks are custom made for every car. Everything is hand built to customer specs. Everything is dynoed before it is shipped and every shock matches. We have a huge data base. Also currently all Pro Stock cars run Penske Shocks. I bracket race and I think we all know how much varying 60' times can be the difference in a first round loss or a final round appearance. I think the information in this post is good. I will never bash another shock companies product. If anybody has questions just PM me.
Competitive Suspension Solutions
[Re: all spooled up]
#1700004
11/29/14 06:49 PM
11/29/14 06:49 PM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
I tried the jack trick on mine when I was winterizing it. My Koni's failed miserably. I think they are single adjustable. Is the single adjustment for compression or extension?
[Re: gregsdart]
#1700007
11/30/14 10:11 AM
11/30/14 10:11 AM
Posts: 3,210 robin hood country
deaks
robin hood country
Can this be controlled to a certain extent by adjusting launch rpm, for e.g loading the converter as opposed to flashing it. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: dvw]
#1700009
12/23/14 08:06 PM
12/23/14 08:06 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Monte,
If you have 90\10s or 3 ways on the front and single adj on the back, you can only afford to buy 2 shocks, which one do you replace
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
