Page 1 of 6 1 2 3 4 5 6
Lots of shock questions lately #1699951
11/17/14 03:07 PM
11/17/14 03:07 PM
North Alabama
Monte_Smith Offline OP
North Alabama
Seen a multitude of shock questions of late. Shocks are one of THE MOST important, yet most overlooked things on many cars. Guys spend tens of thousands of dollars on power and "cool guy" suspension parts and then put $39 shocks on their cars and wonder why it won't work.
I always say, buy as GOOD of a shock as you can afford. Well, if all you can afford is $39 shocks, maybe you should wait a while.
Here is a quick test to see it your front shocks pass the mustard and this could range from a 7 sec car, to a 12 sec car..........Put a floor jack under your car and if adjustable, put your front shocks on "full stiff".........Now jack it up as quick as you can. If the front tire stays on the ground as you jack it up quick...your shocks are JUNK.
Monte
Re: Lots of shock questions lately [Re: Monte_Smith] #1699952
11/17/14 03:21 PM
11/17/14 03:21 PM
tboomer Offline
tboomer  Offline
Monte..I already know my front CEs are junk. So if I race again I will be putting the best front shock I can afford. Your advise did not fall upon deaf ears! Yet!!
Re: Lots of shock questions lately [Re: tboomer] #1699953
11/17/14 03:24 PM
11/17/14 03:24 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Sound advice and I agree often the most overlooked part on a racecar.
Re: Lots of shock questions lately [Re: tboomer] #1699954
11/17/14 03:27 PM
11/17/14 03:27 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
This spring I plan on buying new shocks for my Road Runner. My plan is to go with Afco DA in the rear, and Afco singles in the front with Bounce control. I know DA's in the front would be best, but is it really NEEDED for a bracket car?
Jeff
69 GTX 68 Road Runner
Re: Lots of shock questions lately [Re: Al_Alguire] #1699955
11/17/14 03:29 PM
11/17/14 03:29 PM
tboomer Offline
tboomer  Offline
Al. I wish I knew more about the Vi-King shocks. They seem like a mid level shock. May end up going that way.
Re: Lots of shock questions lately [Re: tboomer] #1699956
11/17/14 04:30 PM
11/17/14 04:30 PM
N.Y.
sixpacksteve Offline
N.Y.
hey monte, Never heard this before. i love sound advise.So bear with me. i thought the front end was suppose to lift up with as little resistance. and come down hard on the shock? i have New QA1's all around,single adjustment. car runs 10.0's comes up maybe 6"at most. which is good for drag racing. i thought i'd be on the back bumper when i launch! not so. thanks
Hell Hath No Fury Like Mine
Re: Lots of shock questions lately [Re: sixpacksteve] #1699957
11/17/14 04:37 PM
11/17/14 04:37 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
Coming from 2 wheels and going around corners, we would do the same thing. Compress the front and rear, and watch how fast they came up...stock valving always looked like a pogo stick, where a good shock would take a couple seconds.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Lots of shock questions lately [Re: sixpacksteve] #1699958
11/17/14 05:16 PM
11/17/14 05:16 PM
North Alabama
North Alabama
Not EVERY car needs to instantly stretch the shock when the car leaves. The point here is buy a GOOD shock. If you need it loose, it can be loose, if you need it tight, it can be tight. When I mention the test above, notice I said adjust your shock "full tight" and do the test. But that doesn't mean you can't loosen the shock up if it needs to be.
Now lets look at something else. Your car is going to snatch the front way harder than you can hit it with a floor jack, so if your shock can't pass the test, when you leave it is likely headed straight to limiter and or topping out shock........which immediately stops weight transfer at THAT point.
Even a low powered car that needs a LOT of pitch rotation, still needs shock control. You don't want it to hammer the stops or top of the shock
Monte
Re: Lots of shock questions lately [Re: Monte_Smith] #1699959
11/17/14 05:17 PM
11/17/14 05:17 PM
OH
TheBlackCar Offline
TheBlackCar  Offline
OH
Monte,
Perhaps you can be the new suspension guy since Dave Morgan retired. Whatcha think? Winter suspension seminars w/ Monte? Maybe a 2 day w/ some N20 on the second day?
I can set-up your first one in beautiful NE Ohio....
Re: Lots of shock questions lately [Re: TheBlackCar] #1699960
11/17/14 05:19 PM
11/17/14 05:19 PM
North Alabama
North Alabama
...........LOL!!!........doubt anybody would show up for that
Monte
Re: Lots of shock questions lately [Re: Monte_Smith] #1699961
11/17/14 05:31 PM
11/17/14 05:31 PM
my own world
theraif Online tonguue
theraif  Online Tonguue
my own world
bought the car in 97 built it raced from 98-2002 with what ever old shock were on the front
run
CE 50/50 on the back
Re: Lots of shock questions lately [Re: Monte_Smith] #1699962
11/17/14 05:32 PM
11/17/14 05:32 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
You don't mean that CLUNK I hear when the front suspension tops out against my trimmed-down control arm bumpers just off the hit, do you?
Perhaps I'll see what a couple of clicks more on the front rebound adjustment does when the car gets back on the track...
Re: Lots of shock questions lately [Re: theraif] #1699963
11/17/14 05:37 PM
11/17/14 05:37 PM
North Alabama
North Alabama
run
So what's your point? I used to run my own car with drilled front stock shocks and some old truck shocks, with homemade extenders and managed to get it down the track. But was it the BEST it could be........hell no........far from it. But a couple years later, that same car with good shocks was going high teen 60fts on a 10.5 tire.
"Good enough" is relative to who is saying it. Your interpretation of that statement and mine are likely different
Monte
Re: Lots of shock questions lately [Re: Monte_Smith] #1699964
11/17/14 05:43 PM
11/17/14 05:43 PM
OH
TheBlackCar Offline
TheBlackCar  Offline
OH
Monte
As my mentor used to say "Good Enough, no faster than you're gonna go!"
Re: Lots of shock questions lately [Re: TheBlackCar] #1699965
11/17/14 06:17 PM
11/17/14 06:17 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
How common is it to see a shock dyno is the pits at a drag race? How many have them back at the shop?
I know in our local Circle Track racing, 20 years ago having a shock dyno was un-imaginable for a local non traveling team. Maybe a couple traveling teams in Winston West (one under Busch) had them. 10 years ago, a few local teams had them. Now many have them. Shock tech has gone up and shock dyno prices have gone down.
Wonder if shock dyno's will get more widespread in Drag Racing too?
Re: Lots of shock questions lately [Re: TheBlackCar] #1699966
11/17/14 06:22 PM
11/17/14 06:22 PM
BigFish69 Offline
BigFish69  Offline
Monte
Do you have any brand shock preference you would recommend for a double adj. rear shock on ladder bar car.
Thanks Tom
Re: Lots of shock questions lately [Re: autoxcuda] #1699967
11/17/14 06:26 PM
11/17/14 06:26 PM
North Alabama
North Alabama
Few teams have their own dynos, because drag cars don't have to change shocks for various tracks like a round track car. We don't really need low and high speed valving changes from track to track. On a drag car, once you get out about 100ft, the shocks do nothing but absorb bumps in the track. Shock control at the hit is what matters.
That said, you do see some shock guys at the tracks these days with dynos, testing and setting up shocks
Monte
Re: Lots of shock questions lately [Re: Monte_Smith] #1699968
11/17/14 06:43 PM
11/17/14 06:43 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Monte
Make it somewhere warm in the winter and I'll be there!
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Lots of shock questions lately [Re: BigFish69] #1699969
11/17/14 06:46 PM
11/17/14 06:46 PM
North Alabama
North Alabama
Monte
Thanks Tom
I get this question all the time and it is a hard one to answer. If you have a 7 sec door car and a 12 sec door car, your shock needs are different. But if you just order a DA shock from Jegs, Summit, whoever, you will get the same shock for both cars.
I see guys say Strange all the time, and they DO make a good shock, but their standard shock, has too soft of valving in it for higher HP cars, yet may be perfect for some. And the same goes for about any other mainstream shock company. You order a generic shock, you GET a generic shock. As with any other parts, you need what YOU need. The best way to get that might be custom. You need to talk with the actual shock company and get a shock YOU NEED. Will this route cost you more........maybe, unless they feel their "shelf" shock will fit your needs.
Now, as to what shocks I use. I generally use Santhuffs, but they ain't cheap. Now does every car out there need $1500 worth of shocks on both ends........No, but you do need a decent shock..............So, my answer to your question, about what shock I suggest..........it depends. But the companies I feel make a GOOD shock, provided you get the right one....probably Strange and Afco are on top of my list. Obviously I am leaving out the more "expensive" shocks like Santhuff, Lamb, Penske, Koni, JRI, etc. but these will ALL be made for your car and are considered custom shocks.
Monte
Re: Lots of shock questions lately [Re: JERICOGTX] #1699970
11/17/14 07:00 PM
11/17/14 07:00 PM
Indy
496 A-body Offline
496 A-body  Offline
Indy
Jeff
I have Afco eliminator big gun doubles on the rear of my car, but Afco Reactor singles in the front with BNC. The reactor singles with BNC definitely DO NOT pass Monte's test as of right now, the gas pressure is so high in them that it is a real chore compressing them to put them on the car and it actually raises the front when installed. I talked to a guy at the last IMIS show and he assured me that the extreme gas pressure was correct for the BNC valving yet when I called AFCO later the guy I talked to said they went out with way too much of a charge and recommended I buy a nitrogen shock charging kit to fine tune, I dont want to do this so I recommend going with eliminator doubles up front and get the BNC if you think you'll need it.
