Need info fast.-2014 ram 2500 18" rim on a 2001? #1699881
11/17/14 02:39 AM
11/17/14 02:39 AM
Western Washington
Sixgun Offline OP
Sixgun  Offline OP
Western Washington
Got a deal lined up for some much needed tires.Found rims, caps and lugs -18x 8's on CL, off a 2014 ram 2500, and another ad for firestone 275/70/18's, both very reasonable.Am planning on buying both tomorrow,
a little late, but want to make sure they'll fit my 2001 CTD?
Thanks in advance for the help, guys!
Casey
Re: Need info fast.-2014 ram 2500 18" rim on a 2001? [Re: Sixgun] #1699882
11/17/14 10:50 AM
11/17/14 10:50 AM
Guitar Jones Offline
As far as I can tell the wheels will bolt up, as for any clearance issues, I don't know.
You might try searching around on the dieseltruckresource.com board.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Need info fast.-2014 ram 2500 18" rim on a 2001? [Re: Guitar Jones] #1699883
11/17/14 02:50 PM
11/17/14 02:50 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Firestone, Bridgestone: Leave 'em.
Mo' Farts
Moderated by "tbagger".
Re: Need info fast.-2014 ram 2500 18" rim on a 2001? [Re: Sixgun] #1699884
11/18/14 01:22 PM
11/18/14 01:22 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
yes they will fit. my friend ran a set of rims off my 2004 ctd on his 1999 cummins. the only thing that wont fit is the rear center caps. the dana 70/80 axle sticks out more then the axle end on the aam axle that the 2014 has. i think my frind said he found a place that makes a shim so you can run the 2014 center cap. mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
