Wow. Slugs are .151" in the hole #1699760
11/16/14 08:29 PM
11/16/14 08:29 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
I knew the compression was going to be low on this 440 but I was hoping for a bit more than that.
I'm thinking...
Poor old Imperial needs more cylinder pressure. Might have to address that some day.
- Stu Harmon
Re: Wow. Slugs are .151" in the hole [Re: feets] #1699761
11/16/14 09:06 PM
11/16/14 09:06 PM
Portland Oregon
69Dartman Offline
69Dartman  Offline
Portland Oregon
Well is there a easy way to get them where they should be? What is it, less then 8 to 1 now as I think they were listed as 8.2 anyways.
My Neon is almost 10 to 1 factory
Life's a little bit better when you hit a Camaro.
Re: Wow. Slugs are .151" in the hole [Re: 69Dartman] #1699762
11/16/14 09:18 PM
11/16/14 09:18 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
Doing the math with the cylinder head, gasket, and piston depth I come up with 8.0 compression. That's a bit low even for forced induction.
- Stu Harmon
Re: Wow. Slugs are .151" in the hole [Re: feets] #1699763
11/16/14 09:27 PM
11/16/14 09:27 PM
IN
ahy Offline
ahy  Offline
IN
Hmmm
Re: Wow. Slugs are .151" in the hole [Re: feets] #1699764
11/16/14 09:34 PM
11/16/14 09:34 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I measured one that came out to 7.8 compression. Talk about a dog!
Re: Wow. Slugs are .151" in the hole [Re: DaytonaTurbo] #1699765
11/16/14 09:36 PM
11/16/14 09:36 PM
Morristown Tn.
71birdJ68 Online content
71birdJ68  Online Content
Morristown Tn.
81/2 to one, in the piston airplane world, that's considered high compression, and requires 100LL.
Re: Wow. Slugs are .151" in the hole [Re: 71birdJ68] #1699766
11/16/14 11:26 PM
11/16/14 11:26 PM
yeah I've ran into SCR's in the 7's (measured). If you ain't going into the short block (boring) I'd get a Hughes cam to build at least a bit more psi & tweak the dist subsystems dead on.
Re: Wow. Slugs are .151" in the hole [Re: RapidRobert] #1699767
11/17/14 01:01 AM
11/17/14 01:01 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Moparts member Jim LaRoy (Formerly "Hey Old Guy", curently "LaRoy Engines") has done several dyno sessions with low compression 440s and has published some impressive numbers even with engines as low as 7.5 to 1. He posts here, FABO and FBBO and even DodgeCharger.com. It might be worth looking into. Well prepped heads benefit any engine, even ones with low squeeze ratios.
Re: Wow. Slugs are .151" in the hole [Re: Kern Dog] #1699768
11/17/14 01:11 AM
11/17/14 01:11 AM
NY NY
3
340duster340 Offline
NY NY
what are the plans for the car?
Re: Wow. Slugs are .151" in the hole [Re: 71birdJ68] #1699769
11/17/14 01:50 AM
11/17/14 01:50 AM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
The twin turbo440 was 8.7:1 and ran on 93 octane with 8 psi boost and no intercooler.
It also handled 17 psi with 93 octane a wee bit of rubbing alcohol through a repurposed nitrous needle.
Plans for the car?
It's a 5100+ lb cruiser. Occasionally driven by an overly enthusiastic maniac. Kinda funny. I beat on that thing harder than I beat on the hot rod.
- Stu Harmon
Re: Wow. Slugs are .151" in the hole [Re: feets] #1699770
11/17/14 02:37 AM
11/17/14 02:37 AM
Southern CA
Colin Frolick Offline
Southern CA
My 71 was close to that. When I put aluminum heads on it they were milled a lot to make up the compression. Then when I built the 493, same heads, we used reverse dome pistons to get about 10:1 with 0.039 quench. Runs great!!
Re: Wow. Slugs are .151" in the hole [Re: feets] #1699771
11/17/14 10:46 AM
11/17/14 10:46 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Change the pistons, I bought a short block like that, the seller thought it was 360 because of a nearby air cleaner.
I stuck cheap sealed power 6 pak pistons in mine and sold the flat tops. It didn't cost me hardly any money to do it. No I did not balance the motor, still running great today 10 years later.
Mine had big ole nasty rust circle about 3" around in one of the cylinders from sitting after a fresh bore and hone. I hand honed and it sealed up fine, it didn't even begin to remove the rust stain when I honed it.
Re: Wow. Slugs are .151" in the hole [Re: feets] #1699772
11/17/14 11:26 AM
11/17/14 11:26 AM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
Dang Kevin ...You're just not catchin a break with that IMP..Sounds like it needs a complete O/H..with better pistons..,, then why not just stroke it, as pistons come with most kits, While you're in there a better cam , then some better heads while you're doin it , $$$$ Why not $$$$$$$$$$$$$..you know how it go's...Good Luck..Larry
Re: Wow. Slugs are .151" in the hole [Re: dynamite] #1699773
11/17/14 12:19 PM
11/17/14 12:19 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
Yeah, I'm fighting that urge. Knowing there is a full EFI system, a pair of turbos, and more 8 piston calipers collecting dust in the garage is killing me.
I'd be installing the EFI system now if there wasn't 84 ounces of R12 in the A/C system. The upper A/C line is a steel, not rubber, and goes directly across the mouth of the throttle body. No way yo put an air filter on it.
If I change the line it would be the proper time to change the compressor.
It's a big ugly slope to fall down. Best to avoid it completely.
- Stu Harmon
Re: Wow. Slugs are .151" in the hole [Re: feets] #1699774
11/17/14 01:21 PM
11/17/14 01:21 PM
"Bench seats and pistol grips"...
moparmoynihan Offline
Well if you're contemplating selling the Parts for the Impy, I'm your guy Feets. A super clean rust free 69 Imperial 2 door is waiting in NY for some parts!! Johnny Brake calipers too!!
1969 Charger R/T D21, A33, B5
1931 ford 5 window coupe, on deuce rails, 392 Hemi, 4 speed
1958 Plymouth Belvedere 440, PB 727, 8 3/4 3.23sg
"Body by Budweiser"
Re: Wow. Slugs are .151" in the hole [Re: feets] #1699775
11/17/14 01:55 PM
11/17/14 01:55 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
so boost it. 6-8lbs should help ya out enough. You can use a carb and wouldn't even need to cool the boost.
Coming soon!!!!
Re: Wow. Slugs are .151" in the hole [Re: Mr.Yuck] #1699776
11/17/14 01:58 PM
11/17/14 01:58 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
I'll never use a carb under boost again. Once you go EFI it's hard to go back.
I'm not selling the parts. I need to get the Imp back together and running so I can concentrate on other things right now.
- Stu Harmon
Re: Wow. Slugs are .151" in the hole [Re: feets] #1699777
11/17/14 02:26 PM
11/17/14 02:26 PM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
You can make plenty of power even with the low compression. There's a writeup over at FABO taking that low comp BB and running thru the dyno while adding cam, intake, headers, etc. I think it ended up around 450hp for nearly squat into the build.
Re: Wow. Slugs are .151" in the hole [Re: feets] #1699778
11/17/14 02:50 PM
11/17/14 02:50 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
What we do with R12 is find a buddy who needs some (always someone with an old car who needs some), hook my gauges to the high side on the one car donating the freon and the low side to the recipient, (I use my 134 gauges and 134 adapters on both cars)pinch off the line to the bottle start both vehicles (if possible) and turn on the AC, you can get pretty much all of it out this way (may need to jump the relay to make the compressor keep pumping after the pressure drops too low in the donor car)and it don't go to waste and Al Gore should be happy. When we put the old R-12 system back together we just put adapters on and evac real good and fill with 134. Even if your car is not running you can still get it down under 50 PSI and if you can figure a way to heat the AC system up a little in your car you can get even more out. Whatever you do do not put propane in an AC system ever! there is a shop in town that does and we keep getting exploded condensers to replace
Re: Wow. Slugs are .151" in the hole [Re: HotRodDave] #1699779
11/17/14 02:57 PM
11/17/14 02:57 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
As for low compression just get a custom cam ground with around 205@.050 and as much lift as possible, then add high ratio rockers to get more flow without increasing the duration. I have seen low compression engines like this one 8.4 compression 5.9 magnum I built get 180PSI with a small cam like that. You could even go with a wider LSA (that cam was 110) to help the turbo and not lose too much cylinder pressure.
