Valley Pan with heat riser blocked #1699598
11/16/14 09:59 AM
11/16/14 09:59 AM
USA
Lawn Monkey Offline OP
USA
I saw it on Overhaulin , 64 Fury 383 , as they were installing the stock intake I noticed that the Valley Pan has a built in heat riser block , where does one buy that type of Valley Pan
Re: Valley Pan with heat riser blocked [Re: Lawn Monkey] #1699599
11/16/14 10:28 AM
11/16/14 10:28 AM
scratchnfotraction Offline
ask for a fel-pro high performance pan when parts clerk looks up a stock fel-pro pan for the 383.
I have one on my 440
it will come with 4-thin gaskets with it also. fixed the intake leak I was having with out them on a stock pan.
Re: Valley Pan with heat riser blocked [Re: scratchnfotraction] #1699600
11/16/14 10:32 AM
11/16/14 10:32 AM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
You need Fel-Pro part number 1214.
Re: Valley Pan with heat riser blocked [Re: TooMany62s] #1699601
11/16/14 01:07 PM
11/16/14 01:07 PM
france
jose jones Offline
jose jones  Offline
france
Your nicely painted intake manifold will not turn black around the sides of the carb where the paint gets fried like the stock gasket.I have run these gaskets for years
Re: Valley Pan with heat riser blocked [Re: jose jones] #1699602
11/16/14 01:21 PM
11/16/14 01:21 PM
USA
USA
Thanks fellas never knew Hi Po Valley Pans existed
Re: Valley Pan with heat riser blocked [Re: Lawn Monkey] #1699603
11/16/14 02:13 PM
11/16/14 02:13 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Order one for a 440 truck and you get the same thing.
Re: Valley Pan with heat riser blocked [Re: 62maxwgn] #1699604
11/16/14 02:51 PM
11/16/14 02:51 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Only if he has an RB engine. B engines need the narrower pan.
I used one of them on my TT440. The back pressure in the exhaust blew one of the plugs out of the pan. It found it's way into a turbo spinning 100,000+ rpm.
Those ports are still punched on the "blocked" valley pans but they aren't knocked out. I doubt it will pose a problem for those without turbos.
Better yet, go with Edelbrock heads. They don't have those ports.
- Stu Harmon
