dtc U1467
#1699581
11/16/14 02:21 AM
11/16/14 02:21 AM
Posts: 10,228 Colleyville
3hundred
Colleyville
Have had some battery troubles with the 2013 Chrysler. Had to jump it off Friday evening. Check engine light came on. Car started fine when I got home, Saturday, battery is dead again. Checked it out and it appears to be code U1467. Any insight on what's going on here?
TIA Robert
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
Re: dtc U1467
[Re: Dcuda69]
#1699583
11/21/14 03:05 PM
11/21/14 03:05 PM
3hundred
Colleyville
U codes are can bus(network) diag codes. May have happened due to the jump start...regardless, you'll have to figure out the battery issue 1st then see if the code returns
Dealer just called, very strange. They replaced the alternator, claiming that's why the check engine light was on. From what happened I figured the alternator was working well? Unless it had a short from being jumped? Wouldn't an alternator set a P code, not a U code?
They tried to sell me differential service, fuel injection cleaning and something else at 34,000 miles. Passed on all. I use Chevron Techron or Seafoam most every oil change, figured on diff and trans service ~ 60,000 miles.
Robert
Re: dtc U1467
[Re: 3hundred]
#1699584
11/21/14 03:31 PM
11/21/14 03:31 PM
Posts: 6,015 Salem
Grizzly
Moparts Proctologist
Salem
Those wonderful dealers! ALWAYS looking out for their Customers$$$!
120 buck an hour to overhaul a one-year-old car. You better let them do it, Robert, cuz, y'know, they are just barely making ends meet! As the dearship owner pulls away in his Ferrari to go catch his private jet to his Tropical Island
Just leave the PIN number, your card and the fillings in Your teeth with them, it'll come back with fresh muffler bearings too.
Mo' Farts
Moderated by "tbagger".
Re: dtc U1467
[Re: Grizzly]
#1699585
11/21/14 03:44 PM
11/21/14 03:44 PM
3hundred
Colleyville
I'll be satisfied if it's fixed and they didn't screw something else up while they had it. STILL surprised they didn't replace the battery. Four days on the battery tender and was still completely, totally hammer dead. Alternator drain? 2.5 days at the dealer, I wonder now if they didn't have it on a trickle charger?
We'll pick it up this evening, hope it starts.
Robert
