best primer #1699512
11/16/14 12:03 AM
11/16/14 12:03 AM
Shippensburg, PA
GardnersGotCudas Offline OP
Shippensburg, PA
what is the best 2k primer that money can buy that does not shrink thanks
Re: best primer [Re: GardnersGotCudas] #1699513
11/16/14 12:50 AM
11/16/14 12:50 AM
Lakewood, Colorado
herkamer Offline
herkamer  Offline
Lakewood, Colorado
You'll get more different answers than there are products available.
With that, anything solvent based will shrink. Period. How much is dependent on the solvents and base materials, and how long you let it cure. If you can let it set, you can sand out any shrinkage with time.
2 products I've used with great success:
Clausen All-U-Need: http://www.smartshoppersinc.com/AutomotiveFinishes/Clausen_Primer.html
Tamco: http://www.tamcopaint.com/hpdtmgr2kprw.html
They are 2 completely different products, both have had great results.
And I NEVER use one system beginning to end, so let the nay-saying begin.
Matt
69 Dart Swinger 340
83 W350, Megasquirted with 46RH
Old news: 72 Demon street/race mobile
Latest: 70 Duster backhalf car
and even more
Re: best primer [Re: herkamer] #1699514
11/16/14 10:53 PM
11/16/14 10:53 PM
Southeast PA
5wndwcpe Offline
5wndwcpe  Offline
Southeast PA
1968 GTX hardtop
1968 Sport Satellite Convertible 383/4spd
1933 Plymouth coupe
2002 Ram 2500 oil burner 4x4
2015 Grand Cherokee
2013 Challenger
1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
Re: best primer [Re: 5wndwcpe] #1699515
11/16/14 10:57 PM
11/16/14 10:57 PM
USA
hudsonhornet7x Offline
USA
Are you looking to spray primer over bare metal, or are you looking for a primer-filler to block sand?
Re: best primer [Re: 5wndwcpe] #1699516
11/17/14 12:07 AM
11/17/14 12:07 AM
Missouri
Challenger Offline
Challenger  Offline
Missouri
SPI epoxy for me.
http://www.southernpolyurethanes.com/
This is what I use as well.
Re: best primer [Re: Challenger] #1699517
11/17/14 12:10 AM
11/17/14 12:10 AM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
SPI epoxy for me.
Here too. Their epoxy, 2k primer, and clears are top notch. As well as awesome customer service and support!
Re: best primer [Re: T2R9] #1699518
11/17/14 01:25 AM
11/17/14 01:25 AM
So. Illinois
bronze69 Offline
bronze69  Offline
So. Illinois
EVERY primer will shrink. Which is why most high end restoration shops will let a vehicle sit in the final coat of primer for at least 30 days before they do the final sand and paint. This allows all of the shrinking to take place before final sanding.
68 Gold Met. 383-4spd Roadrunner 69 T5 Hemi 4-spd Roadrunner 70 Limelight 440-6 Auto Superbird
Re: best primer [Re: bronze69] #1699519
11/19/14 01:50 AM
11/19/14 01:50 AM
Greenville, N.C.
BarrsRestoration Offline
Greenville, N.C.
That is exactly right! It's all about the prep, and that means what is under the primer. Personally, I use all PPG products with very good results. No, it is not cheap. But it hasn't failed me in the past twenty years, either.
If you had asked about the cheapest primer on the market, I would probably say use the brand most have suggested here. But you didn't.
Re: best primer [Re: BarrsRestoration] #1699520
11/19/14 02:04 PM
11/19/14 02:04 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I use dupont nason 2k, since I use dupont products 95% of the time.
I use spi epoxy, not as a building primer, but to seal freshly stripped/blasted metal.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: best primer [Re: Silver70] #1699521
11/19/14 02:41 PM
11/19/14 02:41 PM
Waddell AZ
azblackhemi Offline
azblackhemi  Offline
Waddell AZ
This is what I use. It's an Epoxy primer with excellent adhesion to bare metal that also is a very high build fill primer also. Being able to prime and fill with one product saves me a lot of time and money. I've also always believed that all primers shrink but with this stuff I've never noticed any shrinkage. All the high end resto shops in the area are using this now.
Re: best primer [Re: azblackhemi] #1699522
11/19/14 03:47 PM
11/19/14 03:47 PM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
Since I dry sand every step down to the final wet sand of 600 I have found Martin Senours Tech Prime hard to beat. As mentioned before I also leave the last coat before final sand sit for as long as is possible to let any uglies creep back before color is applied.
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Re: best primer [Re: bronze69] #1699523
11/19/14 10:48 PM
11/19/14 10:48 PM
Missouri
Challenger Offline
Challenger  Offline
Missouri
This is correct BUT not all primers shrink. SPI epoxy primer does not shrink. Typical 2K primers will shrink.
