Sway bars on truck ??? #1699374
11/15/14 05:54 PM
11/15/14 05:54 PM
Kalispell Mt.
HotRodDave Offline OP
Kalispell Mt.
So if one is solid and one is hollow but the diameter is the same is the solid one going to resist sway more? I know the outside of the bar does most of the work but does the solid center help at all?
Re: Sway bars on truck ??? [Re: HotRodDave] #1699375
11/15/14 06:19 PM
11/15/14 06:19 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Solid would be stiffer!
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Sway bars on truck ??? [Re: astjp2] #1699376
11/15/14 06:28 PM
11/15/14 06:28 PM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
I'm not home right now to pull out a strength of materials book and display some torsion equation, but there are equations specifically for solid and hollow bars.
Re: Sway bars on truck ??? [Re: MuuMuu101] #1699377
11/15/14 06:33 PM
11/15/14 06:33 PM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
Yep I agree, solid is stiffer.
http://www.1speedway.com/swaybar375.htm
Re: Sway bars on truck ??? [Re: brads70] #1699378
11/15/14 08:43 PM
11/15/14 08:43 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
What truck?
Mopar to the bone!!!
Re: Sway bars on truck ??? [Re: 72Swinger] #1699379
11/16/14 12:59 PM
11/16/14 12:59 PM
Fly Over States
P
PHJ426 Offline
PHJ426  Offline
P
Fly Over States
Get a truck with torsion bars and factory Bilstein shocks and a solid sway bar ...
Re: Sway bars on truck ??? [Re: PHJ426] #1699380
11/16/14 02:55 PM
11/16/14 02:55 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
My little truck is a 1992 D250 Club Cab long bed diesel. It has the heavy suspension package for towing and still tried to fall over on freeway off ramps despite the large front sway bar. I stuffed a 7/8" sway bar under the back of it and there was a night and day difference.
I waited FAR too long to do that.
- Stu Harmon
Re: Sway bars on truck ??? [Re: feets] #1699381
11/17/14 03:45 PM
11/17/14 03:45 PM
Kalispell Mt.
Kalispell Mt.
I have a 2000 dakota 4x4 that I tow way too much with, it has a hollow front bar, I have a 3 parts durangos, 2 have the same size bars but solid and the 01 R/T has an even bigger bar that is solid. I was wondering if I should install the same size diameter solid bar or should I just put in the R/T bars?
I have taken off the bars temporarily for hunting season for when I am out in the woods so just trying to decide witch one to put back on in 2 weeks. Dakota is a V6 5 speed all the Durangos are V8s.
Re: Sway bars on truck ??? [Re: HotRodDave] #1699382
11/17/14 09:32 PM
11/17/14 09:32 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I'd slam the R/T bars on it and call it done.
- Stu Harmon
Re: Sway bars on truck ??? [Re: HotRodDave] #1699383
11/18/14 12:03 AM
11/18/14 12:03 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
We don't know the wall size of the tubular bar, but in this case its moot. A solid bar of the same size will have more resistance than the tubular bar of the same OD. The even bigger R/T bar that is solid has the most resistance of the lot. I 2nd feets recommendation.
Do you have to take it completely off? I'd try just pulling out the link on one side.
Re: Sway bars on truck ??? [Re: TC@HP2] #1699384
11/18/14 03:04 PM
11/18/14 03:04 PM
Kalispell Mt.
Kalispell Mt.
Would the R/T bar be over kill?
I remove the whole thing, it is real easy, (the rear bar is like a pencil so I just leave it and I hear the durango bar won't fit but they are much bigger) I guess since they are so easy I could just try all the bars to see what I like
Re: Sway bars on truck ??? [Re: HotRodDave] #1699385
11/18/14 08:47 PM
11/18/14 08:47 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
If it was 2" bar stock it would be overkill.
I imagine you'll be satisfied with the improvement.
- Stu Harmon
Re: Sway bars on truck ??? [Re: feets] #1699386
11/19/14 09:00 AM
11/19/14 09:00 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
The r/t sways aren't all that aggressive. Put them on, I think you'll be happy. Hotchkis makes fromt/rear sways that are even stiffer than the stock r/t sways
The 'equation' for a hollow bar is to pretend you're dealing with 2 seperate solid sways. If you have a 7/8" tube with 1/8" thickness, then the diameter of the open space is 5/8"
You would calculate the strength of a solid 7/8" bar, then subtract the strength of a 5/8" solid bar
Sounds like a lot, but as mentioned, there's a torque involved with sways, so the farther out from the center, the more work the tube does. You can use a larger hollow bar to increase the spring rate of the sway bar, without adding additional weight
**Photobucket sucks**
