Holley blue pump failed.... #169936
12/18/08 12:20 PM
12/18/08 12:20 PM
Tampa, FL
tpabayflyer Offline OP
Tampa, FL
Maybe 8 hours run time total...... Using -6 line to carb and parts of stock 5/16 line and -6 line as the return..... It is getting power and no go???.. Does it need to be cleaned??? rebuild kit?? or just get a holley black pump with my summit discount coupon??
Pump is located below the fuel cell and using a russel metal filter on the feed side before the pump. I should mention I tried this same pump while using my stock,rusty gas tank and after it plugged up the filter 5 times, I chucked it in favor of an nice aluminum RCI cell......
TBF
71 Challenger 528 Hemi project
09 Gr Cherokee 5.7 hemi in da house!!
Re: Holley blue pump failed.... [Re: tpabayflyer] #169937
12/18/08 12:23 PM
12/18/08 12:23 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Mine died after 700 miles, get a Mallory. their seems to be a rash of bad holley pumps
Re: Holley blue pump failed.... [Re: ademon] #169938
12/18/08 12:28 PM
12/18/08 12:28 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
2 years and about 9,000 street miles, no complaints but the noise..it seems they are either good and last awhile. Or bad and quit soon.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Holley blue pump failed.... [Re: GoodysGotaCuda] #169939
12/18/08 03:42 PM
12/18/08 03:42 PM
Columbus Ga
reflections7 Offline
Columbus Ga
Mallory 110 very quite.
Re: Holley blue pump failed.... [Re: reflections7] #169940
12/18/08 06:29 PM
12/18/08 06:29 PM
MG, Brazil
v8punch Offline
v8punch  Offline
MG, Brazil
Mine blue pump sounds like 747!!!
Re: Holley blue pump failed.... [Re: v8punch] #169941
12/18/08 06:42 PM
12/18/08 06:42 PM
Fredericktown, PA 15333
maundmotorworks Offline
Stealth poster
Stealth poster
I got over 30,000 street miles on the Holley Blue pump in my '90 W250 CTD. No complaints here!
Maund Motorworks--supplier of high performance Mopar engines--specializing in B, RB, and Hemi. www.maundmotorworks.com
Re: Holley blue pump failed.... [Re: tpabayflyer] #169942
12/18/08 06:44 PM
12/18/08 06:44 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
The inlet line needs to be bigger than the feed line. #8 min or even better #10 line(1/2") I know people will say theirs works great with 5/16" suction line, but that has not been my experience.
Many blue pump failures and vapor lock situations occure because of line sizing.imo
Your filter should be on the outlet side of the pump so the pump gets full flow from the tank now that you have a clean fuel cell and you can strain your fuel when you add it.
Re: Holley blue pump failed.... [Re: tpabayflyer] #169943
12/18/08 06:50 PM
12/18/08 06:50 PM
Cincinnati, Ohio
Cincinnati, Ohio
TBF
You don't think all that rust going thru that poor pump didn't shorten it's life? I know you had a filter in front of the pump but the rust still get's to the pump. Been there.
Re: Holley blue pump failed.... [Re: Challenger 1] #169944
12/18/08 07:15 PM
12/18/08 07:15 PM
Hampton, Ga.
70dart360 Offline
Green Meister
70dart360  Offline
Green Meister
Hampton, Ga.
TBF
I agree, I always put a filter before and after the pump, but then still its not a 100% guarantee it'll keep the stuff out of it.
70 Dart Swinger 72 D-100 440 shortbed 76 Pinto, 68k 21mpg!
Re: Holley blue pump failed.... [Re: ademon] #169945
12/18/08 07:27 PM
12/18/08 07:27 PM
pacific northwest
W
wings471 Offline
wings471  Offline
W
pacific northwest
I have had three (3) uno dos tres of those junk pumps go bad on me. ALL three (3) uno dos tres leaked. One of the pumps came with the summit fuel cell kit I bought 2 yrs ago and have 700 +/- miles used. The other 2 were pumps to replace the original leaky pos. I run a return line also. I have since bought the aeromotive (2) and haven't had any problems. I'm thinkin' those Kung Pow Holleys aren't from around here. Last time I will ever buy a Horrey pump.
Re: Holley blue pump failed.... [Re: wings471] #169946
12/19/08 01:58 PM
12/19/08 01:58 PM
Tampa, FL
Tampa, FL
ooooooooooh.... I undastand gwasshoppa.... Has any used a rebuild kit on one of these?? I am going to take it apart and check it out just for fun and see what the deal is. It worked just fine up until I had it towed home 2 months ago..... AS far as the filters go, I have a 40 micron? size filter before the pump. I also have larger fram paper filter bofore it goes up to the carbs. When I put the new cell in, I changed the paper filter and there was definately evidence of rust particles inside so the pump had some crap run through it for sure. The pre-pump filter was not a paper element, just more of a screen type so the really fine particles would still make it through.
I think they offer a rebuild kit so should I try it and see what happens or just get a new one??? I will report back with what the guts of the pump looks like.... TBF
Re: Holley blue pump failed.... [Re: tpabayflyer] #169947
12/19/08 04:58 PM
12/19/08 04:58 PM
Cincinnati, Ohio
Cincinnati, Ohio
Re: Holley blue pump failed.... [Re: Challenger 1] #169948
12/19/08 11:46 PM
12/19/08 11:46 PM
Southington, Ohio
dm69charger Offline
dm69charger  Offline
Southington, Ohio
I went thru two Holleys. Both of them had less than two hours time on them. Put a Mallory in it and it has been working great for a year now. It is much quieter too.
-Don
Re: Holley blue pump failed.... [Re: dm69charger] #169949
12/23/08 02:34 PM
12/23/08 02:34 PM
Tampa, FL
Tampa, FL
Well.. I took it apart and there was a bit of whitish dust in there and I cleaned it out.... Sprayed a little wd-40 in there and now it works as advertised... go figure.. TBF
Re: Holley blue pump failed.... [Re: tpabayflyer] #169950
12/23/08 03:48 PM
12/23/08 03:48 PM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
The 67 Cuda had a blue pump and it shorted out
and had a little fire, so I orded another and it lasted for years.
Had a blue on the 65 Sport Fury for 4 years.
A few 4x4 toys I had, and a racing partner and I ran
a low 8 second front engine dragster on a blue.
We even use a Holley blue pump as a water pump for a
water cooled 40 hp 5 cylinder 2stage compressor.
Easy to rebuild, last for years.
Now, the 70 Cuda runs a B.G. 400, you want to
talk about noise!
Snap your neck, mega G-force launch, is all I want!
