mig welder sputtering out of tip #1699109
11/14/14 09:25 PM
11/14/14 09:25 PM
Harrisburg Pa. 17112
moparmikethree Offline OP
My mig welder which is from Harbor Freight ,used to work perfect now the welds are terrible and it sputters out of the tip. The gas is full and is working ,good ground clean surface. I know its not the best welder but what went wrong
Re: mig welder sputtering out of tip [Re: moparmikethree] #1699110
11/14/14 09:31 PM
11/14/14 09:31 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Is it pushing wire or just spinning the rollers?
New tip?
Good ground?
Leads under the door in the right orientation for gas?
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: mig welder sputtering out of tip [Re: GoodysGotaCuda] #1699111
11/14/14 10:06 PM
11/14/14 10:06 PM
SW CO
HemiSportFury Offline
SW CO
If everything is clean including tip and nozzle and it is feeding wire your wire speed is to low for your current setting.
'64 Sport Fury, 528 Hemi, FiTech EFI, 4-speed, 4.10 Dana 60
'57 Belvedere 2dr sedan, current project in process
'19 Cherokee Trail Hawk Elite
'03 Ram 2500 CTD HO, 6-speed 214,000 miles and still going strong
Re: mig welder sputtering out of tip [Re: HemiSportFury] #1699112
11/14/14 11:06 PM
11/14/14 11:06 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Rusty wire. If its not bright shiny copper, its rusty.
Swap the wire. Use compressed air to blow out the liner and the roller wheels. Changing the tip wouldn't hurt. Worst case you'll have to change the liner.
Actually, depending on the size of the roll you could pull off enough to get to a clean layer of wire. Usually at least 1/8" down.
