spark plug torque spec for 2012 dodge avenger #1698865
11/14/14 05:39 AM
11/14/14 05:39 AM
md
mopars4ever Offline OP
md
what is the spark plug torque spec for 2012 dodge avenger with a 2.4
Re: spark plug torque spec for 2012 dodge avenger [Re: mopars4ever] #1698866
11/14/14 06:04 PM
11/14/14 06:04 PM
13/16 or 3/4 or 5/8 plugs
Re: spark plug torque spec for 2012 dodge avenger [Re: RapidRobert] #1698867
11/15/14 05:24 AM
11/15/14 05:24 AM
md
md
5/8 IIRC. I will double check tomorrow.
Re: spark plug torque spec for 2012 dodge avenger [Re: mopars4ever] #1698868
11/15/14 05:30 AM
11/15/14 05:30 AM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I have always used 25 foot pounds for every engine I ever worked on...aluminum or iron heads. On the aluminum I also use ant-seize, but that is the only difference. I have been doing it that way for over 50 years, but I would be willing to change if there is a better way
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: spark plug torque spec for 2012 dodge avenger [Re: Polarapete] #1698869
11/15/14 05:38 AM
11/15/14 05:38 AM
md
md
On a iron head I never torqued one to spec. Aluminum I worry a little more.
Re: spark plug torque spec for 2012 dodge avenger [Re: mopars4ever] #1698870
11/15/14 08:57 AM
11/15/14 08:57 AM
Ringtown, Pa.
Dartsport540 Offline
Ringtown, Pa.
Alldata says 20 ft. lbs.
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
Re: spark plug torque spec for 2012 dodge avenger [Re: Dartsport540] #1698871
11/16/14 02:14 AM
11/16/14 02:14 AM
md
md
Ok, thanks for the help.
