too much converter?
#1698783
11/13/14 11:24 PM
11/13/14 11:24 PM
Posts: 984 Tennessee
Hemi ragtop
Tennessee
I love reading the posts of you racers. I on the other hand, have a 100% street car. Granted, it has a lot of "race" parts, not the least of which is a 540" HEMI. My question is: have any of you ever installed TOO MUCH converter? I asked the advise of a 727 guru that I still respect, and allowed him to choose the converter for my 4,175lb. convertible street 66 coronet. It has the aforementioned HEMI, producing over 600 ft.lb. of torque, with a 3.54 gear. I was always disappointed in the "rubber band" acceleration. The tack never moved, as the speedometer caught up. I really never paid attention, when I installed it, but upon removing it, I find that I have a 8" converter that is much more appropriate for a light car with a high rpm engine with a 4:56 gear! I am replacing it with an 11" "tight" converter. Any experience with "TOO MUCH" converter? I would just "blow through" that little converter every time I tried to launch the car. If so, what improvements did you see in et and MPH?
Re: too much converter?
[Re: Hemi ragtop]
#1698784
11/14/14 12:39 AM
11/14/14 12:39 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Whos 8" converter and what stall was it advertised at from your 727 guru? I hope you didn't do this blindly. I figure you had to have some input in this. So now, your installing a 11" "tight" converter, who specked that for you and whats its advertised stall. Also whos vert did you go with this time? Your looking for improvement "estimates guestimates" between the two verts with out providing enough info about the two verts IMO Also, at what rpm were considering you were at "blow through" ![](/ubbthreads/images/graemlins/bow.gif)
[Re: Hemi ragtop]
#1698789
11/14/14 10:26 AM
11/14/14 10:26 AM
Posts: 10,021 Frostbitefalls MN (Rocky&Bullw...
gregsdart
There are so many variables that it is impossible to give a decent answer to this one. No converter expert here, but It sounds like the driveability "feel" is as important to you as all out performance, which it should be with a street strip car. You may be more satisfied with a matched smaller duration cam/tighter converter combo. How much duration do you now have, and where does to torque start to come in? with 540 cubes, a STOCK stall range 426 Hemi converter is a good fit if built strong enough to handle the torque. It will probably stall minimum 3400 rpm. They won't live without some improvements though,AMHIK. Mine lasted six passes behind a 535, 3600+ stall out of that stock factory 10 3/4 converter.
