Small Block Pushrod ID? #1698676
11/13/14 05:14 PM
11/13/14 05:14 PM
Leucadia, Ca.
V
vdriver Offline OP
vdriver  Offline OP
V
Leucadia, Ca.
In my never ending quest to organize my junk, I came across a box of small block valve train stuff. It contained about 50 pushrods, of which there are 3 distinct varieties.
Anybody know the correct applications for 'em?
Top one has ball/ball ends, 7-7/16" long, .313" diameter.
Middle has pressed in ends, 7-1/2" long, .28" diameter.
Bottom has 1 pressed end and the other is tapered, just under 7-5/8" long, .28" diameter.
Re: Small Block Pushrod ID? [Re: vdriver] #1698677
11/13/14 05:15 PM
11/13/14 05:15 PM
Leucadia, Ca.
V
vdriver Offline OP
vdriver  Offline OP
V
Leucadia, Ca.
Re: Small Block Pushrod ID? [Re: vdriver] #1698678
11/13/14 05:16 PM
11/13/14 05:16 PM
Leucadia, Ca.
V
vdriver Offline OP
vdriver  Offline OP
V
Leucadia, Ca.
Re: Small Block Pushrod ID? [Re: vdriver] #1698679
11/13/14 05:29 PM
11/13/14 05:29 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
The ones from my 360 look like the one in the middle. I'll look at them more closely when I get home. They were originally out of a 76 360.
Re: Small Block Pushrod ID? [Re: vdriver] #1698680
11/13/14 09:51 PM
11/13/14 09:51 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
OEM Small block push rods from a hydraulic lifter engine (late 273, 318, 340, 360) are all the same length and ball and ball.. Push rods from a solid lifter engine like the 273 are much longer and are the cup and ball type.
Re: Small Block Pushrod ID? [Re: MoparforLife] #1698681
11/13/14 10:16 PM
11/13/14 10:16 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Mine are 7 7/16" long and just over 1/4" thick.
Re: Small Block Pushrod ID? [Re: burdar] #1698682
11/14/14 12:26 AM
11/14/14 12:26 AM
Leucadia, Ca.
V
vdriver Offline OP
vdriver  Offline OP
V
Leucadia, Ca.
Thanks!
