finally found solution to heating my garage #169837
12/18/08 09:20 AM
12/18/08 09:20 AM
eastern, pa.
cudabitten Offline OP
eastern, pa.
I posted a while ago about needed a heater for my two car garage. I got many replies with all kinds of good advice. I tried three different heaters, two small electric(5000)BTU, and one propane (18000) BTU. The Propane one finally brought the temperature up within a reasonable amount of time, from 45 to 55 in about 35 minutes, however I also installed a CO detector and after about 5 hours the alarm went off. So back to the store it went. I bought an electric heater from Grainger (18000) BTU, only catch was, (and I was avoiding)I had to install a 240v/30 outlet plus a 30 amp breaker. Now the garage stays at about 55 degrees while I'm not working out there and I can turn the thermostat up and get it to stay at 65 degrees while working. It only took 30 minutes to move from 45 to 60 degrees. Just wanted to follow-up to anyone who is still having problems.
Re: finally found solution to heating my garage [Re: cudabitten] #169838
12/18/08 09:24 AM
12/18/08 09:24 AM
btomasko Offline
btomasko  Offline
How bad is your electric bill?
Re: finally found solution to heating my garage [Re: btomasko] #169839
12/18/08 10:08 AM
12/18/08 10:08 AM
eastern, pa.
eastern, pa.
Yeah, good question. Not sure yet, I just installed this last week. But I will take note. On the other hand, you could just resign the electric bill increase to part of the cost of restoring a car. The only other option is to wait until March/April to get to work out there again.Plus I really want to get this project done, can't stand having it in pieces.
Re: finally found solution to heating my garage [Re: cudabitten] #169840
12/18/08 11:12 AM
12/18/08 11:12 AM
Nanaimo, B.C.
GwaiiEagle Offline
Mannix
GwaiiEagle  Offline
Mannix
Nanaimo, B.C.
I use a woodstove.
Re: finally found solution to heating my garage [Re: cudabitten] #169841
12/18/08 11:13 AM
12/18/08 11:13 AM
Southern Maryland
klunick Offline
klunick  Offline
Southern Maryland
I had an outlet installed in my new garage just for that reason. MD has deregulated so our rates are just nuts. Last year I went with a 30k BTU propone heater. It heated up pretty quick and only used less than 2 tanks, costing me $40 for the whole winter. I am rarely out there for more than 5 hours at a time and it doesn't run continously so I have never noticed any problems.
67 Barracuda FB 69 Superbee "Southern Maryland: If you want a good looking woman, you had better bring her with you"
Re: finally found solution to heating my garage [Re: klunick] #169842
12/18/08 01:01 PM
12/18/08 01:01 PM
CENTRAL MINN
1965_PLYMOUTH Offline
CENTRAL MINN
I've got a buddy that heats his house with one 7500 watt Farenheit heater with a built in fan. his house is a one level two bedroom home, 28X34. he has the heater mounted in the basement and has the basement door open all the time. he has another small 1250 watt oil filled heater in his kitchen(center of the house)to help with the 10 degree and colder days. his house stays 64-66 all winter. it adds $100.00-$125.00 a month to his electric bill, but it's still cheaper than LP or fuel oil. I've got a wood stove in my shop 60X100.
Re: finally found solution to heating my garage [Re: 1965_PLYMOUTH] #169843
12/18/08 01:14 PM
12/18/08 01:14 PM
I'd be shivering like crazy
Re: finally found solution to heating my garage [Re: cudabitten] #169844
12/18/08 01:22 PM
12/18/08 01:22 PM
Aurora, Oh.
max_maniac Online happy
max_maniac  Online Happy
Aurora, Oh.
I need to do something like this. My garage is 24x40 and insulted so I'm wondering what size I would need to heat it kind of like yours. 18000 BTU's enough? Thanks.
Re: finally found solution to heating my garage [Re: max_maniac] #169845
12/18/08 01:45 PM
12/18/08 01:45 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Gas appliances are generally rated in BTU"s per Hour, but electric heaters are usually rated in Kilowatts. 18,000 BTUH is approx. 5kw.
My garage is also 24'x 40' (with 12.5' ceilings) and it well insulated with two insulated OH doors, one man door and 6 double pane windows.
I am currently using a 5kw construction heater (similar to that described by the OP) and it has no problem keeping my shop at the desired 55 deg F with an outdoor ambient of 5 deg F.
That having been said, 5kw is too small and my permanent heater is 10kw. Check this out;
http://www.ultimategarageheater.com/garage-heater-calculator.php
Cheers,
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: finally found solution to heating my garage [Re: DPelletier] #169846
12/18/08 01:55 PM
12/18/08 01:55 PM
michigan
tonycpe Offline
tonycpe  Offline
michigan
Hard to beat a Mr. Heater ceiling mount with power vent/
Old Fogey Racing Ltd.
Re: finally found solution to heating my garage [Re: tonycpe] #169847
12/18/08 02:16 PM
12/18/08 02:16 PM
abodyman Offline
super street
abodyman  Offline
super street
Look up BTU (British thermal units)
and figure out how many square feet of space You have. Then You can figure out how big of a heater or what btu You need.
BTU= the amount of energy it takes to change 1 square foot of space 1 degree. IIRC ?
anyway, there are btu calculators available, just do a search.
Re: finally found solution to heating my garage [Re: cudabitten] #169848
12/18/08 02:19 PM
12/18/08 02:19 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Got a HOT DAWG and have no regrets.
Not a good thing for a dusty shop though as the fan REALYY moves air !!!
Re: finally found solution to heating my garage [Re: Stanton] #169849
12/18/08 02:25 PM
12/18/08 02:25 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I use a Reznor waste oil burner.
I get my fuel for free. Works great open the over head door and it recoupes the temp in 15 min.
Gotta know folks lookin to get rid of drain oil.
It works just like a fuel oil furnace, just more filters and a good pre heater.
Re: finally found solution to heating my garage [Re: Stanton] #169850
12/18/08 02:26 PM
12/18/08 02:26 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Those Hot Dawg's are nice, very compact and can be mounted what 1" from the ceiling?
But I do some painting in my shop that's why I like radiant gas heat. It's silent and sturs no dust up when I fire it up to help dry my paint. And when I open the garage door to move trucks around the heat stays in the shop.
Re: finally found solution to heating my garage [Re: Challenger 1] #169851
12/18/08 03:33 PM
12/18/08 03:33 PM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
For me 50 is a perfect temp to be working in the garage, I would never make it any warmer and when not working I'd run it at 35 or 40.
For now I'm suck with a propane heater that I just run as needed. I have a 100,000 BTU natural gas furnace that I could hang in there but I plan on moving in the next year or so. I'll save it for the next garage!
Re: finally found solution to heating my garage [Re: abodyman] #169852
12/18/08 03:55 PM
12/18/08 03:55 PM
DPelletier Offline
DPelletier  Offline
Actually, it's the amount of energy required to raise one lb of water 1 degree Fahrenheit.
There are many variables to take into account to do a proper heat loss calculation, but I posted a link to a simple calculator above that will work for this.
Re: finally found solution to heating my garage [Re: DPelletier] #169853
12/18/08 08:54 PM
12/18/08 08:54 PM
Woodbridge
Tommy The Chryco Offline
Woodbridge
i was running propane but is to dangerous, now I bought a 130,000 btu kerosene heater/blower no vent required...works great, 5 gallan tank is only $20.00 the heater comes with a thermestat.
Fight the Good Fight- Elastomeric Bumpers and The Better "Shaker kits"
Re: finally found solution to heating my garage [Re: cudabitten] #169854
12/18/08 09:16 PM
12/18/08 09:16 PM
Phoenix, AZ
3
38371cuda Offline
38371cuda  Offline
Phoenix, AZ
I use a dayton gas 45000 BTU and it works killer in my 700 ft detached. Of course I'm in Arizona so i only usae it about 2 months a years for a couple hours in the moring. Lit the pilot, and test fired it today for the coming cold front(low 40's). LOL
Re: finally found solution to heating my garage [Re: max_maniac] #169855
12/19/08 12:46 AM
12/19/08 12:46 AM
eastern, pa.
eastern, pa.
Actually, all three electric heaters I purchased were rated in BTU'S not kwatts. Its good to compare BTUS's when comparing propane with electric. The It dosent matter what it stands for as long as you know that 18000 BTU's is rated to heat a 500 square foot space. I leaned this the hard way by going cheap at first with the 5000 BTU heaters. It wasnt until I purchased the 18000 BTU propane heater that I realized the difference in heating potential. My garage is only a 20 x 20 = 400 square feet but I oversized the heater slightly so it wouldn't run as often. Like I said I went to three different stores, and returned three heaters until I got the right match. this heater is only 16" by 12" by 12". My garage is insulated as well. However your garage is 960 square feet. Its easy to figure out what heater size you need just go to the grainger web site and read the descriptions. They will tell how many BTU's the heaters are and what size garage they will heat. You might want to get two smaller units and heat from opposite directions.
Re: finally found solution to heating my garage [Re: cudabitten] #169856
12/19/08 12:59 AM
12/19/08 12:59 AM
WV
bacaruda Offline
bacaruda  Offline
WV
Propane heated hot water radiant floor, is nuts.
Tankless, outside vented.
