neat dolly system for my engine/tranny/suspension #169806
12/18/08 08:41 AM
12/18/08 08:41 AM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
Hey gang..
Wanted to share a cool tool a friend, Dave aka 68RRFlyer, made for me.. It's a dolly/cart for my hemi/tranny/k-member assembly. I'll be using this to hold the drivetrain and then lower the body on it..... one more step closer on the hemi Charger.......
Troy
Houston Mopar Connection Club
Re: neat dolly system for my engine/tranny/suspensio [Re: hemi68charger] #169807
12/18/08 08:42 AM
12/18/08 08:42 AM
Houston, Tx
Houston, Tx
Other side...
Troy
Re: neat dolly system for my engine/tranny/suspensio [Re: hemi68charger] #169808
12/20/08 05:49 PM
12/20/08 05:49 PM
Portland, OR
shawge Offline
shawge  Offline
Portland, OR
Looks very nice. Would you please post some pics w/ the K-frame off? Any rough measurements you could provide? I'm looking to make my own and would like to get an estimate for materials to purchase.
Re: neat dolly system for my engine/tranny/suspensio [Re: shawge] #169809
12/20/08 05:54 PM
12/20/08 05:54 PM
Houston, Tx
Houston, Tx
Sure... I'll try something before the end of the week.. I'll make sure it's ok with my friend who made it for me.. Don't wanna infringe on any future business plans..... He's a whip when it comes to this stuff and it's not even his profession.. Smart guy.
Troy
Re: neat dolly system for my engine/tranny/suspensio [Re: hemi68charger] #169810
12/20/08 06:06 PM
12/20/08 06:06 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Is it setup for a coke bottle type jack for the transmission?
Re: neat dolly system for my engine/tranny/suspensio [Re: Snoopy] #169811
12/20/08 06:44 PM
12/20/08 06:44 PM
Houston, Tx
Houston, Tx
Not sure about the question, but the tranny will be bolted to the engine and both will eventually be placed on the dolly and positioned under the car.....
Troy
Re: neat dolly system for my engine/tranny/suspensio [Re: hemi68charger] #169812
12/20/08 09:36 PM
12/20/08 09:36 PM
Snoopy Offline
Snoopy  Offline
The jack is used to raise or lower the transmission during installation. It makes the procedure a lot easier.
Re: neat dolly system for my engine/tranny/suspensio [Re: hemi68charger] #169813
12/20/08 09:40 PM
12/20/08 09:40 PM
Southeast Virginia
68jim Online content
68jim  Online Content
Southeast Virginia
Troy,
This is one I made for myself. I have a lift so I made this one a little higher to make it easier to work on. The K-frame sits on some teflon strips and I tack welded a scissor jack on the back to keep it from shifting around (Sandy Reda suggestion) It worked just fine and now it is looking for a new home...
68 Hemi Road Runner
Re: neat dolly system for my engine/tranny/suspensio [Re: 68jim] #169814
12/20/08 09:42 PM
12/20/08 09:42 PM
Southeast Virginia
Southeast Virginia
Without the motor...
Re: neat dolly system for my engine/tranny/suspensio [Re: 68jim] #169815
12/20/08 09:46 PM
12/20/08 09:46 PM
Snoopy Offline
Snoopy  Offline
Jim, I lightened your picture up to show a little more detail.
Re: neat dolly system for my engine/tranny/suspensio [Re: Snoopy] #169816
12/21/08 01:09 PM
12/21/08 01:09 PM
Southeast Virginia
Southeast Virginia
Snoopy, thanks. Here is another shot from a different angle. I had to cut a small notch from the one side to clear the Milodon oil pan, it was one of those that has the triangle shaped pans and it required just a little extra room to fit.
Re: neat dolly system for my engine/tranny/suspensio [Re: 68jim] #169817
12/21/08 01:12 PM
12/21/08 01:12 PM
Southeast Virginia
Southeast Virginia
Dolly in action!
Re: neat dolly system for my engine/tranny/suspensio [Re: 68jim] #169818
12/21/08 02:35 PM
12/21/08 02:35 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
How much do the ends of the k frame clear your runners on your lift? My lift is just like yours
Re: neat dolly system for my engine/tranny/suspensio [Re: Snoopy] #169819
12/21/08 05:11 PM
12/21/08 05:11 PM
Houston Texas
PAINT IT BLACK Offline
Got a CHIP on my shoulder
Houston Texas
Re: neat dolly system for my engine/tranny/suspensio [Re: PAINT IT BLACK] #169820
12/21/08 05:55 PM
12/21/08 05:55 PM
Snoopy Offline
Snoopy  Offline
That's like hunting squirrels with a howitzer.
Re: neat dolly system for my engine/tranny/suspensio [Re: PAINT IT BLACK] #169821
12/21/08 07:24 PM
12/21/08 07:24 PM
Houston, Tx
Houston, Tx
Well, Steve you need to stop eating popcorn and come over and help me get the ole' hemi under the '68...
Troy
Re: neat dolly system for my engine/tranny/suspensio [Re: hemi68charger] #169822
12/21/08 10:19 PM
12/21/08 10:19 PM
Houston Texas
Houston Texas
I'd be up for helping.
Re: neat dolly system for my engine/tranny/suspensio [Re: JDMopar] #169823
12/22/08 09:31 AM
12/22/08 09:31 AM
Long Island NY
ErikR Offline
ErikR  Offline
Long Island NY
I'd like to know too? Jim this setup looks great but I thought that the k frame width would interfere with any 4-post? Is that brand wider than others?
Re: neat dolly system for my engine/tranny/suspensio [Re: ErikR] #169824
12/22/08 11:10 AM
12/22/08 11:10 AM
Southeast Virginia
Southeast Virginia
You are absolutely correct about the K-frame interference. When I measured it out the K-frame is about 3" wider than the inner flange on the lift. I originally wanted to install the motor/K-frame with the rest of the front suspension in place which would have been easy with the 2 post design. I even considered moving the car forward on the lift to let the front section overhang enough to install everything. That idea did not last long as I had visions of the car tipping over off the lift... I looked at the design of the lift and thought "what a bummer" I just needed a few more inches to make it work. The lift has a 2" lower flange on the inboard side of each track that is used for holding the plastic drip trays. It came with a heavy tray to be used with a jack for lifting the car and I noticed that it did not sit on those inner flanges but rather it sat on the top of the track where the strength is at. The basic upside-down "U" shape of the track is the main structural designed support, and that is where all the strain would be and not on the inboard flanges. I decided that all I needed was a couple of reliefs notched into the flange and the K-frame would fit. It worked quite nicely and all I did was make a few slices and bent the 4" notches down with a pipe wrench. If you notice I had made a support for the Road Runner using the front bumper bracket mounts and some scrap steel which placed the weight at the very end of the track by the cross support of the lift. I tried to make the tracks flex by the area I cut since I still was concerned about the integrity but the tracks were still rock solid. When it came time to install the motor-trans/K-frame everything worked out great. I had about 1/4"-1/2" clearance on each side and the whole installation evolution lasted less than a half-hour from placing the rig under the car to the torque on the last bolt. Once that was done I just got the pipe wrench out again and a few C clamps and welded it back up again. I would not leave the notches permanent since I will need to drive the car across it, but for the short time I needed the extra room I saw no real harm. I'm sure the lift OEM would never endorse "any" mods to their products, but I'm only reporting what worked for me in my situation...
68 hemi Road Runner
Re: neat dolly system for my engine/tranny/suspensio [Re: 68jim] #169825
12/22/08 11:25 AM
12/22/08 11:25 AM
Southeast Virginia
Southeast Virginia
I found one other picture that shows how close the K-frame fits between the tracks. I did not take a picture of the clearance at the closest point. Hope this helps others that may have the same issues using a 4 post lift to install the motor from underneath.
