Bolt on Fiberglass trunk lids? #1697768
11/11/14 09:48 PM
11/11/14 09:48 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Anybody ever use a fibreglass trunk lid before but left it as a bolt on? Was it worth the change, or is a lot of the weight savings in the hinges?
Unlimited sells a fiberglass trunk lid for my car that should be about 25-30lbs lighter, but not sure if it is worth it if the hinges are where a lot of the weight is, as well as how strong/flimsy it might be with the opening and closing of the trunk a street car sees...I would imagine its no different then a glass hood, but then I could be wrong
Re: Bolt on Fiberglass trunk lids? [Re: mshred] #1697769
11/12/14 01:08 AM
11/12/14 01:08 AM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
Glass is the only way to go. Don`t look back just do it. MUCH LIGHTER .This one`s an Unlimited one.
Much easier to access everything .
chryco
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: Bolt on Fiberglass trunk lids? [Re: chryco] #1697770
11/12/14 01:48 AM
11/12/14 01:48 AM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
chryco
Im looking for a bolt on, as in bolts to the stock trunk hinges, not a pin on where the entire trunk lid is removed...Just not practical for a street car like I have in my opinion, especially on a windy day with no where to put it lol
Re: Bolt on Fiberglass trunk lids? [Re: mshred] #1697771
11/12/14 01:53 AM
11/12/14 01:53 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Does stinger/AAR make one?
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Bolt on Fiberglass trunk lids? [Re: mshred] #1697772
11/12/14 01:57 AM
11/12/14 01:57 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Not worth it IMO, if you have a Abody. Its good High weight ballast.
My Abodys like 2950, Not going to do the trunk lid, myself.
Re: Bolt on Fiberglass trunk lids? [Re: 1967dartgt] #1697773
11/12/14 01:58 AM
11/12/14 01:58 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Not worth the trouble for the maybe one thousandth of a second difference it would make..... Especially on a street car.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Bolt on Fiberglass trunk lids? [Re: Sport440] #1697774
11/12/14 02:05 AM
11/12/14 02:05 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I agree, a glass trunk lid would be the last place to LOSE weight on a strip car.
Mopar to the bone!!!
Re: Bolt on Fiberglass trunk lids? [Re: mshred] #1697775
11/12/14 02:22 AM
11/12/14 02:22 AM
fresno ca
mikeysmopars Offline
fresno ca
I put a glass one on mine and made it fit the stock hinges and added the stock latch assy Takes an extra 30 pounds out & still looks right.
Founder and CEO of the Central Valley Mopar Drag Pack
Re: Bolt on Fiberglass trunk lids? [Re: mikeysmopars] #1697776
11/12/14 06:53 PM
11/12/14 06:53 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
So it was 30lbs weight savings even using stock hinges and latch? That is HUGE
For those saying not to take weight out from there...I run a nitrous bottle, which adds 25lbs, so this can make up for that. My car is a FAT PIG at close to 3500lbs with me in it, so to be honest, I am not too concerned about removing 30lbs off the rear end.
For me what will make it worth it or not is how much weight it will save...everything adds up, and hopefully this with my glass bumpers front and back and possibly light weight brakes this winter will shed a decent amount of weight of the car...if not for increased e/t's, then for less stress on the drivetrain parts. I look at lost weight as a win/win
Re: Bolt on Fiberglass trunk lids? [Re: 1967dartgt] #1697777
11/12/14 06:54 PM
11/12/14 06:54 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Not sure if they do, I was looking on the Unlimited website for a new hood since I sold my AAR cowl the other day and noticed the rear glass decklids that are bolt on.
Re: Bolt on Fiberglass trunk lids? [Re: mshred] #1697778
11/12/14 07:15 PM
11/12/14 07:15 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
I have a glass lid on my Demon and want to replace it with a stock metal one. Just doesn't look that good to me.
Re: Bolt on Fiberglass trunk lids? [Re: Airwoofer] #1697779
11/12/14 07:18 PM
11/12/14 07:18 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
What about it looks bad???
Re: Bolt on Fiberglass trunk lids? [Re: mshred] #1697780
11/12/14 07:40 PM
11/12/14 07:40 PM
south central pa
bdaz smblk Offline
bdaz smblk  Offline
south central pa
aar makes a glass bolt on trunk lid.I don't know how much of a savings it is but I have one and it is very nice
3120lb, small block, 10.5" tire, NA, through exhaust, full int, WITH 83/4 REAR, 9.0 at 150mph
Re: Bolt on Fiberglass trunk lids? [Re: bdaz smblk] #1697781
11/12/14 07:55 PM
11/12/14 07:55 PM
gregsdart Offline
gregsdart  Offline
If you can't find a bolt on for your car, you can do what I did and fab up the parts on a pin on type hood to bolt to the factory hinges, and make a latch assembly out of aluminum plate, a return spring and a wood block glued to the lid. Mine saved 35 lbs. I needed to get weight off the back of the car. After the glass trunk lid, I moved the battery to in front of the radiator, and went with lexan in the rear glass. How much weight you need back there is very car specific. I needed a LOT less to make the car work.
Re: Bolt on Fiberglass trunk lids? [Re: gregsdart] #1697782
11/12/14 08:01 PM
11/12/14 08:01 PM
gregsdart Offline
gregsdart  Offline
latch
Re: Bolt on Fiberglass trunk lids? [Re: mshred] #1697783
11/12/14 08:24 PM
11/12/14 08:24 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
Mostly the paint is faded and cracking. Plus the thing is a little thicker than steel. It is for a 72 Demon / Duster and has the Go wing holes. When I get the steel one painted and installed this will be for sale. It bolts on like a normal trunk lid and uses the stock latch.
Re: Bolt on Fiberglass trunk lids? [Re: Airwoofer] #1697784
11/12/14 08:38 PM
11/12/14 08:38 PM
new jersey usa
11secdart Online content
11secdart  Online Content
new jersey usa
I have an AAR bolt on trunk lid on my Dart, its a very nice piece. I even have the trunk lock in it. You can`t even tell its fiberglass unless you look real close.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: Bolt on Fiberglass trunk lids? [Re: 11secdart] #1697785
11/13/14 12:27 AM
11/13/14 12:27 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
me to!
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Bolt on Fiberglass trunk lids? [Re: gregsdart] #1697786
11/13/14 12:30 AM
11/13/14 12:30 AM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Thats pretty neat! Luckily though they made bolt on lids for my car, and they weigh exactly the same as the pin on, just cost a bit more lol
Re: Bolt on Fiberglass trunk lids? [Re: mshred] #1697787
11/13/14 12:56 AM
11/13/14 12:56 AM
hustlin hoosier Offline
AAR makes one , we just installed one in our new 68 barracuda .. It uses factory latches and hinges. The fit was excellent.
